Rear Spring Outer Mount
Old Nov 14, 2006 | 08:28 AM
SPIKESDAD's Avatar
SPIKESDAD
Default Rear Spring Outer Mount
Replaceing The Bushings On The Rear Spring Outer Mount On My 78. The Outer Hole On The Spring Does'nt Line Up Directly With The Hole In The Trailing Arm. Seems To Be Off At About A One Inch Angle. This About Normal ??
Old Nov 14, 2006 | 08:53 AM
tracdogg2's Avatar
tracdogg2
That's normal. Once the car is on the ground everything should line up.
Mike
Old Nov 14, 2006 | 09:30 AM
SPIKESDAD's Avatar
SPIKESDAD
Thanks--thought I Broke Something
To Rear Spring Outer Mount
