rollcage
Old Dec 7, 2006 | 09:54 AM
Twin_Turbo's Avatar
Twin_Turbo
Originally Posted by 427SIXPACK
COOL ........how did you do that ?
SolidWorks 2007
Old Dec 7, 2006 | 04:22 PM
Mark_Milner's Avatar
Mark_Milner
Originally Posted by 73C34me
For the posted examples; it looks like the rear down tubes are going to the differential crossmember instead of the frame rail in the area of the shock mount. is this correct? thanx
There are two crossmembers by the rear end. One mounts the differential, the other ties the frame together. Use the one in back that ties the frame. The one the differential mounts on is a soft mount from the factory and often uses hard mounts in a race car.
A good idea is to remove the differential mount to save weight and fabricate a bracket from the frame crossmember to support the differential. It also improves access for work.
Old Dec 7, 2006 | 04:37 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
Originally Posted by 84rzv500r
Because I complained about the fit and they said send "us drawings of what you need" and they bent it and sent it to my specs for VERY little money.
I have the pinion pieces and a main hoop diagonal and all of the X bracing...
Do you have copies of those drawlings?
Old Dec 7, 2006 | 08:55 PM
84rzv500r's Avatar
84rzv500r
Yes
Old Dec 7, 2006 | 09:46 PM
73C34me's Avatar
73C34me
I have not thought about making a bracket to hang the diff. from the frame cross member, might be good. but 2 weeks ago I boxed the fixed cross weld on brackets (diff. cross member mounts to these) r to the frame rails so that it cannot twist free under power.(not sure if this is a clear expl.)
Old Dec 10, 2006 | 02:00 AM
Mark_Milner
The problem is not so much the mounting cups, but the rubber cups in the crossmember. Most race cars have the mounting cups gussetted to the frame to stiffen. But you have to get rid of the rubber.
and after you do that, you still have about 30 lbs of steel that duplicates the croassmember that sits 6 inches further back.
Old Dec 10, 2006 | 05:42 AM
Twin_Turbo's Avatar
Twin_Turbo
if you really want it tight weld the crossmember to the frame and drill the storage area to have access to the diff bolts.
Old Dec 10, 2006 | 10:07 AM
73C34me's Avatar
73C34me
gonna go look at the frame ater tt last idea...
