remote starter connection
Old Dec 28, 2006 | 11:46 PM
driver68's Avatar
driver68
Default remote starter connection
sorry for the very stupid question, but when connecting a remote starter (to bump the engine), the red wire goes to battery, and the black wire goes I'm assuming to a connection on the starter solenoid? which one? I see 2 - one with very big black wire and one with a small wire.
Old Dec 29, 2006 | 12:56 AM
tfi racing's Avatar
tfi racing
You're close,put one clip on the big starter lead and the other on the small starter lead.If your car is old and original enough,it may have a resistor bypass terminal on the solenoid as well,just ignore that one.
Old Dec 29, 2006 | 11:36 AM
jnb5101's Avatar
jnb5101
ther's two small wires on the solenoid. one is S (start) the other is R (run). you want to put 12 volts on the S terminal. hook one wire from your switch to the big starter wire that goes to the battery, the other on the S terminal. don't forget to pull the coil wire to prevent starting.
Old Dec 29, 2006 | 12:45 PM
Vettkeeper's Avatar
Vettkeeper
Just in case make sure it's out of gear, or in park with the brake set and wheels chocked. Don't ask me how I know.
To remote starter connection
