Alternator light
Old Jan 13, 2007 | 05:31 PM
SPIKESDAD's Avatar
SPIKESDAD
Default Alternator light
Been playing with a pesky little electrical problem. My alternator light glows continually. Alt. output is good-apx 60 amps. Battery checks out good. always starts strong. light glows a little brighter at idle and dims as rpms go up,but never out. A mechanic in our shop said, sounds like it could be a bad ground. Can only find two grounds in the AIM man. Neg batt cable & engine block to frame. I am sure there must be more. But where???
Old Jan 13, 2007 | 05:55 PM
Big2Bird's Avatar
Big2Bird
Default How it works is the start.
When you turn on the key, power flows from the battery, thru the light ,to the field of the alt. As engine speed increases, the output voltage increases, and the field current is supplied from the output of the diode trio. When the voltage on these two circuits are about the same, the light goes out.
Your dim light is a result of the diff in voltages of these two circuits.
1)Battery undervoltage.
2)Bad gauge fuse
3)Bad alternator
4)Resistance in the light circuit. IE, bad plug in alt, bad connection on the circuit board, corroded light socket,etc.
Good luck. It just takes time to find it. If you tested the batt and alt, it's #4
Old Jan 13, 2007 | 06:29 PM
SPIKESDAD's Avatar
SPIKESDAD
THANKS--I'll start at the begining and work through
Old Jan 14, 2007 | 10:09 AM
Bongaroo's Avatar
Bongaroo
Check the diodes in the alternator. Car parts stores like advance or carquest should have one in the store. My alternator had a shot diode and gave me this exact problem. It was even more annoying because it was screwing with my choke relay. What year though?
Old Jan 14, 2007 | 01:13 PM
SPIKESDAD's Avatar
SPIKESDAD
1978 With L48 &auto
Old Jan 14, 2007 | 01:24 PM
Big2Bird's Avatar
Big2Bird
Yep. That will do it too. On early 80 cars with electronic gauges, this will also make them go wacko.
To Alternator light
