transmission conversion?
Old Jan 16, 2007 | 10:54 PM
KunkFunk's Avatar
KunkFunk
Default transmission conversion?
can get your auto converted into a 4-speed? if so can you give me a price range?
Old Jan 17, 2007 | 01:18 AM
Vette80regon's Avatar
Vette80regon
Keisler
Plenty of threads on this subject. Pretty spendy to make the conversion but, from what you'll read on their products, plenty of up-side, very very little on the negative.
Old Jan 17, 2007 | 09:47 AM
Durango_Boy's Avatar
Durango_Boy
There are a lot of threads about the GM and Ford T5 5-speed transmissions and how to put them into your cars. If you're going to the trouble of switching...maybe go with a T5?
I know you'll have to find a pedal assembly...anyplace that salvages Vettes will have one. You'll need a shifter plate, shifter, transmission, pedals, linkages, clutch assembly, and probably a few other goodies I forgot about.
Old Jan 17, 2007 | 09:57 AM
69camfrk's Avatar
69camfrk
From: GA "When I grow up, I'm gonna get a Trans Am and run from the cops". Direct quote from my 4yo son.
Keisler sells bellhousings, pedals, and such and will sell them seperate from their 5 speed kit. I didn't look at your profile, but you can get a decent T-10 for 5 or 6 hundred bucks. Add another 2 hundred or so for a new hurst shifter. You can pick up used bellhousings for 100 bucks or so or buy new from keisler for $199 I think. Their pedal assys are about the same price. I would think you can make the conversion for $1500 give or take a dollar or two. Don't get me wrong, I would love to have one of those five speeds but they are pricey. I'm considering a 4 speed swap in my '80.
Old Jan 17, 2007 | 10:25 AM
Durango_Boy
I can find T5s pretty regularly for $700 or less and some shipping.
Old Jan 17, 2007 | 11:11 AM
69camfrk's Avatar
69camfrk
Matt, how big of a deal is the t-5 swap. Bellhousing, linkage etc?
Old Jan 17, 2007 | 11:15 AM
Durango_Boy
Well, we've been going through this is a few threads. Bernie and Norval have done the swap, and me and a few others are planning to. The swap includes a '93 T5 or less, with an '85 truck bell housing, and a .5" spacer between the transmission and bell house. The TH350 yoke will transfer over I think, and the drive shaft may need to be cut. If you go with a hydraulic clutch like most do, which is also an easy conversion...you don't have to mess with all the linkages.
http://forums.corvetteforum.com/show....php?t=1583978
http://forums.corvetteforum.com/show....php?t=1591961
Old Jan 17, 2007 | 12:22 PM
MS69 350/4-speed's Avatar
MS69 350/4-speed
I called a Keisler recommeded dealer and asked what it would cost from top to bottom ( drop off Pick up when its done deal ) to get the work done and they said everything for 5,000.
Kind of pricey.... If you do not wnat to do the work yourself... So I backed away from buying an auto car. I figured by the time I bought the car made the conversion I would have more money in it than its worth and would be money ahead to pay a little more for a 4-speed.
Bought a 71 4-speed and Glad its a stick, so much more fun to drive then autos.... no offense autoguys.....
Old Jan 27, 2007 | 01:07 PM
Durango_Boy
The advantage of finding a cheap auto car and converting it is the removable cross member. I know that's not what should sway someone, but it's a cool thing to have if you find a cheap auto over a more expensive manual car.
To transmission conversion?
