68 block cast question
Old Jan 20, 2007 | 06:21 PM
revupL78's Avatar
revupL78
Default 68 block cast question
Hi guys. Was a 3935439 Block used in a in a 68 390hp car.My book says this is a 435hp car but the car in question has 439 block and 3937793 intake and rochester carb. The Stamp pad is T0715IL
185427887 matching the title. Is this ok
Old Jan 20, 2007 | 06:35 PM
Duke94's Avatar
Duke94
My "Corvette by the numbers" book says 3935439 was late 1968 and early 1969 block used for 390 HP (2 bolt main) and 400, 430, 435 HP (4 bolt mains). Block used only after January 1968.
Old Jan 20, 2007 | 07:21 PM
FrankVincent's Avatar
FrankVincent
Account disabled by user request 5 Jan 09
T0715 = Tonawanda, July15 (1968)
IL = 427/390hp with 4speed
185427887 should be 18S427887
27887 serial number = August 8, 1968 birthday(approx)
Old Jan 21, 2007 | 10:46 AM
international blue's Avatar
international blue
To authenticate it you would compare the casting date of the block, the stampings on the pad and the general configuration of the car. What is the car if I may ask...? Coupe or convert and colors/options and body trim tag date?
To 68 block cast question
