Headlight Capsule adjuster
Old Feb 3, 2007 | 04:49 PM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Default Headlight Capsule adjuster
I'm trying to reassemble my headlights and when installing the headlight capsule adjusters I ran into a problem. The plastic tab that sticks out from the two screw holes seem to not be flexable enough to tighten down. This piece is opposite the headlight adjuster screw. Looking at the AIM and catalogs it looks like it just screws down flexing on the alum. ramp. Reviewing all my old capsules, the tab has broken off. How does it work?
Old Feb 3, 2007 | 04:52 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
Old Feb 3, 2007 | 04:53 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
Old Feb 3, 2007 | 07:22 PM
Duke94's Avatar
Duke94
There is a groove machined into the head of the adjusting screw that fits into a tab on the headlight bucket. You can just see it on the left side of this photo.
Old Feb 3, 2007 | 08:45 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
Your tab is broken off too. See the white piece of plastic that is on the tab is not there.
Old Feb 3, 2007 | 08:56 PM
Duke94's Avatar
Duke94
It's all there, doesn't show up to well in the photo. The piece is actually new, I don't recall it having the finger sticking out as shown in your photo of the kit.
Old Feb 3, 2007 | 09:10 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
I guess that is why I'm confused. I guess I cut it off.
Old Feb 4, 2007 | 02:08 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
Bump.
Old Feb 4, 2007 | 02:24 PM
Restorod '79's Avatar
Restorod '79
I just put that same rebuild on mine. The little plastic arm rested on the alum. support behind the bucket, sort of acting as a shim/slide. I put a little dielectric grease on it to help settle the bucket in place.
Old Feb 4, 2007 | 02:31 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
That's what I thought. I guess I need to bring them in the house to soften up the plastic.
To Headlight Capsule adjuster
