Question for the more experienced.
Old Feb 4, 2007 | 01:56 PM
79C3kid's Avatar
79C3kid
6th Gear
Default Question for the more experienced.
Hey guys, im new to this site, but you all seem to have more experience than me with Corvettes. I just got some new magnum roller tip rocker arms from Competition Cams' for my 79 vette. I ordered them from an Ecklers magazine, But when i got them in the mail, I opened the box, and there was the instructions sheet, and it said that I cant use the old pushrods with the new rocker arms. So i went back to the Ecklers magazine and looked for some pushrods, but they dont sell them, and it doesn't say anything about needing new ones... so do you guys think I really NEED new pushrods, or are they just trying to get me to spend more money?
One other quick question. How much hp do I get from taking off the mufflers?
Please help
Thanks.
Old Feb 4, 2007 | 02:46 PM
Gordonm's Avatar
Gordonm
It is a good idea for new pushrods but not always needed. The pushrod tip wear to the old rocker arms and when you have new rockers you have old pushrod tips. This will sometimes put an uneven wear pattern on the rockers and wear them out quickly. Go to one of the catolog speed shops and get the pushrods. They will be cheaper and be able to help you out better.
As far as the mufflers it depends on wha ttype are on the car. Sometimes you can lose HP by pulling off the mufflers. If you have the stock mufflers they are robbing some HP. Get a good set of performance mufflers and you will have a decent sounding car with HP to boot.
Old Feb 4, 2007 | 09:46 PM
80vettefan's Avatar
80vettefan
what he said, will it run with the old push rods? yep. but why take a chance on wearing out your new rocker arms over some inexpensive push rods?
Old Feb 4, 2007 | 11:19 PM
mr nasty's Avatar
mr nasty
If you are running guide plates, you will want to make sure you get a hardened pushrod.
greg
Old Feb 5, 2007 | 01:24 AM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
A roller tipped rocker needs proper length
pushrods to place roller on center of valve
the warning is about length.
quick test to see why;
take 1 old rocker off
dye the top of the valve stem (where rocker mates)
put new roller tip on
use orig pushrod, adjust
use starter to cycle motor (do not run !!!)
remove rollertip rocker
look at top of valve stem
is the wear (absence of dye) centered?
You might need pushrod guides also.
Please research proper rollertip rocker use.
It is hard to explain but the rocker must be paralell
to deck.
[ O ]
_________
Old Feb 5, 2007 | 11:42 AM
75 Hot One's Avatar
75 Hot One
Please help
Thanks.
As mentioned above, power gain depends on specifics of your situation-what type of engine, what type of exhaust pipes, what type of old mufflers, what type of new mufflers. The basic issue is: how much of a restriction is your current exhaust system providing to the flow of exhaust gases. If you're looking for a ballpark figure, as I recall from some old magazine articles, going from OEM style mufflers to free flow mufflers where the pipes don't provide too much of a restriction can release somewhere between 5 & 15 HP.
Old Feb 5, 2007 | 12:13 PM
79C3kid's Avatar
79C3kid
6th Gear
Well, i had the stock mufflers on, and took them of, now it's just 2 and a half inch pipe all the way from the converter.
To Question for the more experienced.
