Where is this oil coming from???
Old Feb 19, 2007 | 07:43 PM
69any1's Avatar
69any1
Default Where is this oil coming from???
First off... When my vet was in blocks when i got it i noticed a little oil in the same spot.. Cleaned it up and nothing until now.. month later maybe.. The reason the oil is so long. there was a long piece of grass that the oil formed around..
Old Feb 19, 2007 | 07:47 PM
Durango_Boy's Avatar
Durango_Boy
Ooh that's a good one.
First I would jack up the car, get under it, and look inside that side of the frame. See if there is any oil INSIDE that frame rail. Maybe it's entering the frame further up, and while driving it moved backwards, and drips out to the floor.
Check the whole frame all the way up to the front.
The only fluids at the back would be brake fluid, gasoline, or shock absorber oil. Depending on the shock...that may be the case...but it's not int he right place.
Old Feb 19, 2007 | 07:50 PM
greyghost79's Avatar
greyghost79
interesting. differential oil??? leaking out and rivuleting down the spring then dripping off the end???? that's about all i can think of.
Old Feb 19, 2007 | 07:52 PM
69any1's Avatar
69any1
Well... I will get under there and look but before i ever started the vette or drove it. I had oil in the same spot.. Nothing. been driving it for about 3 weeks now nothing prior but i washed it and waxed it yesterday... Could there be a connection?? hmmmm
greyghost79
is it dripping out directly under the tailpipe??? i've seen tailpipes drip some oil when it's blowing by in the cylinders then out the exhaust. just another thought.
Old Feb 19, 2007 | 07:53 PM
Durango_Boy
Ooh good call. I forgot about diff oil. Any pics of that?
Old Feb 19, 2007 | 07:54 PM
greyghost79
hmm.... again, is it coming out under the tailpipe? could be you squirted water up the pipe and your getting exhaust "grime" running out.
Old Feb 19, 2007 | 07:55 PM
69any1's Avatar
69any1
I will look tomorrow and take more pics
Old Feb 19, 2007 | 07:56 PM
69any1's Avatar
69any1
The car hasnt moved since i washed it yesterday.. I dont think its coming out of the tail pipe!!!!
Old Feb 19, 2007 | 07:57 PM
69any1's Avatar
69any1
Ive got side tail pipes sorry!!!!
Old Feb 19, 2007 | 07:59 PM
Durango_Boy
Can you say for sure if the fluid is engine oil or maybe brake fluid?
Old Feb 19, 2007 | 08:03 PM
69any1's Avatar
69any1
Let me go look at it again and i will take a close picture of it so if u can tell brb
Old Feb 19, 2007 | 08:13 PM
69any1's Avatar
69any1
pics on the way
Old Feb 19, 2007 | 08:14 PM
Durango_Boy
pics on the way
Did you happen to smell the fluid? That's usually the best way to finger a fluid aside from looks. VERY bad and dirty brake fluid can sometimes look like engine oil but them still smell different.
Old Feb 19, 2007 | 08:20 PM
69any1's Avatar
69any1
Heres what i see and found.. NOTHING... lol
No signs of any brake fluid and oil splatter anywhere
And a shot of my baby resting
Old Feb 19, 2007 | 08:21 PM
69any1's Avatar
69any1
I smelled it... and im quit not sure.. kinda gassy smell
Old Feb 19, 2007 | 08:24 PM
Durango_Boy
It does look like engine oil. You're also right, and nothing else seems to be leaking. That cross member LOOKS like it's saturated...but how it got that way is the mystery.
To Where is this oil coming from???
Old Feb 19, 2007 | 08:27 PM
PEPTO77's Avatar
PEPTO77
any chance it could be a small gas leak up above picking up the softened undercoating from the frame, tank or crossmember and dripping on the floor.
Old Feb 19, 2007 | 08:28 PM
75 Red Vert's Avatar
75 Red Vert
Hmmmm - small gas tank leak coming from the top of the tank, picking up gunk running down side of tank and dripping on floor. Maybe check gasket around input to gas tank.
Old Feb 19, 2007 | 08:29 PM
69any1's Avatar
69any1
I got under it for about 5 minutes looking and feeling... i cant find anything.. I dont understand why it happens once in awhile...
