that is close, i would be worried about it hitting when under a hard load like a good launch. you seriously dont have any issues with it that close while at wot? if you dont that is great.
Yup, you contested. I guess it was a long time ago.
Originally Posted by torqvette
Live with the extra 20 lbs and spend the $800 that you'd spend on a new hood in your engine.
Originally Posted by Durango_boy
...and if that engine won't fit under a stock hood?
If you're running a roots supercharger or a tunnel ram you could glass in a bigger cowl or a scoop.
I run a Victor Jr manifold with a 4 inch air element with the filter top under my stock hood. I just use a drop base air cleaner. And I still have enough room to squeeze in a nitrous plate.
Pics to prove it?
Oy, time to dig through the harddrive.
torqvette - I still find it very hard to believe that all that fits just fine. I personally have not ever had a clearance problem but I didn't have the motor height you did. I wonder how SO MANY other guys ave clearance problems with a stock motor, aftermarket intake, and a stock carb. What got yours to tuck in so nicely under a stock hood?
OK... do you need a video with footage of the setup and me closing the stock hood on top of it? Should I get the local paper to prove the date aswell?
And no my control arms did not fall off, Chevrolet made the Corvette, not Ford.
Do you know the total height from the carb flange to the top of the lid? Summit is saying that it's 4.25" which seems awfully high for a drop base and 3" tall filter.
