Wheel Well Finish
Old Mar 13, 2007 | 09:58 PM
randyward's Avatar
randyward
Default Wheel Well Finish
Can any of you experienced 'Vetters tell me what the proper finish is for the wheel wells on my '68? Is it unfinished like the underside?
Thanks!!!
Old Mar 14, 2007 | 02:36 PM
eastltd's Avatar
eastltd
I suspect it is raw fibreglass with undercoating in places. I just cleaned the wheelwells on my 73 and that's what I found. I spoke with a vette bodyman last night who tells me the undercoating was there to protect the glass from stone damage. Apparently, a stone hitting the underside of a fender without u/coating could cause the topside paint to "spider".
I plan to paint the underbody of my car including the w/wells a slate gray color to match the glass look and re-apply the U/coating as close to the factory look as possible.
Good luck with the clean-up
Old Mar 14, 2007 | 03:01 PM
Toms-68's Avatar
Toms-68
Spray on undercoating will suffice.
Old Mar 14, 2007 | 03:51 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Wheels got a spritz of semi-flat black during blackout, but application was uneven and spotty at best. The entire well will not be evenly painted. Fronts and rears will show the most paint; sides and top little to none.
Not sure '68s got any type of undercoating; later years did.
Old Mar 14, 2007 | 04:37 PM
7T1vette's Avatar
7T1vette
If you're not going the NCRS scoring route, just use a hi-pressure soap spray and flush on the wells, let them dry and spray 'em with Krylon semi-flat black. That's probably not "by the book", but it sure makes them look like new. It is surprising how much better the whole car looks after the wells are finished. I guess the brain just expects to see crud in there.
Old Mar 14, 2007 | 05:47 PM
randyward's Avatar
randyward
Default Thanks
Thanks for the update on the wells. I'll go with a thin coat of undercoat in the wells. The rest of the underside is bare and looks good.
To Wheel Well Finish
