Lacquer Thinner
Old Mar 25, 2007 | 12:12 PM
stinger12's Avatar
stinger12
Default Lacquer Thinner
I 've been using water to remove the paint stripper residue from my car (as well as a scotch bright pad). I would like to double up the process with some lacquer thinner. What type of thinner do you recommend...just the ordinary stuff from Home Depot? Do I use a rag soaked in lacquer thinner and just wipe on/wipe off to remove contaminants? Will this stuff need to be removed with water after use...or is it safe on fiberglass panels?
Old Mar 25, 2007 | 12:26 PM
stinger12's Avatar
stinger12
bump
Old Mar 25, 2007 | 12:42 PM
wnmech's Avatar
wnmech
When I stripped mine I also wiped it down with water and the lacquer thinner that is sold at Home Depot for $10 dollars a gallon. Just be careful not to use it around a gas water heater if its in your garage that stuff is extremely flammable.
Old Mar 25, 2007 | 12:54 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
i would follow the strippers instructions to a T....you don't want to contaminate the surface to be painted accidentally
Old Mar 25, 2007 | 01:41 PM
69FASTFUN's Avatar
69FASTFUN
When I stripped my Vette I used the stripper and then neutralized that with soap and water and then I used a scotch brite pad and lacquer thinner and then washed with soap and water and the fiberglass was real clean.
Old Mar 25, 2007 | 02:07 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Stop by your local auto paint supply shop and ask them for their cheapest "wash" thinner. The last time I got a gallon of Nason brand it was under $8.00.
Old Mar 25, 2007 | 02:28 PM
7T1vette's Avatar
7T1vette
Lacquer thinner is great stuff, but it can do some real damage to brain cells! Keep good access to open air.
Old Mar 25, 2007 | 04:29 PM
Artsvette73's Avatar
Artsvette73
Use the thinner you'll be good.
Old Mar 25, 2007 | 06:36 PM
brdd's Avatar
brdd
From: Minnesota in the summer, Las Vegas in the winter
.........tell me about it..........
To Lacquer Thinner
