Replace 75 Door handle opening control
Old Apr 9, 2007 | 08:49 PM
WVR 75's Avatar
WVR 75
Default Replace 75 Door handle opening control
My driver inside door handle broke off in my hand.
Its about a $70 dollar part, but what is the best way
to remove the door panel and install the not yet ordered part.
Any help is appreciated,
William
Old Apr 9, 2007 | 09:14 PM
Durango_Boy's Avatar
Durango_Boy
Door panel:
Remove the door pull strap - 2 Phillips screws.
Remove lock **** - 1 clip (Use small flathead.)
Remove panel screws - 1 Phillips each on doorjamb fore and aft.
Window crank - 1 clip (Use small flathead.)
Door handles - 1 Phillips and slide handle out.
Note: Power window door panels will not have a window crank or clip.
Pop the plastic Velcro clasps with your fingers. Lift and slide off.
The door latch mechanism is much harder as you have three linkages to detach, and three bulkhead Phillips screws to take out. Maybe even a water gutter to pull out.
The mechanism itself will be a real pain in the butt to get out. Twist it and rotate it until it fits through the opening that GM made too small.
Replace with the good pricey part that I think you are getting anyway, and replace by reversing the process outlined above.
Good luck.
Old Apr 9, 2007 | 09:26 PM
WVR 75's Avatar
WVR 75
Durango Boy,
Thanks for the detail info. I will be working on the door
panel after I order and receive the part.
WVR 75
Old Apr 9, 2007 | 09:36 PM
Durango_Boy
Originally Posted by WVR 75
Durango Boy,
WVR 75
No problem. It's a fun job, and by fun I mean scary, and by scary I mean have your friend mechanic do it for beers.
Old Apr 9, 2007 | 09:37 PM
Greg's Avatar
Greg
Just another Corvette guy
William,
Is the part that broke the actual chrome door handle piece you pull with your hand or was it the inner mechanism? If it's just the chrome handle I'm pretty sure I've got an extra one I'd be happy to send you.
Best,
Greg
Old Apr 9, 2007 | 09:50 PM
WVR 75's Avatar
WVR 75
Greg,
The handle is ok, the machine screw treads in the control are
striped, and maybe part of the control mech is worn/broken.
I figured that as long as I was diving into the door I should
order and replace the control mech, its 32 years old.
Thanks for you generous offer
William
Old Apr 10, 2007 | 01:06 AM
75 Red Vert's Avatar
75 Red Vert
Be sure and pick up a long flexible magnet for all the stuff you drop way down deep into the door.
Old Apr 10, 2007 | 03:55 AM
DMONSVETTE's Avatar
DMONSVETTE
This link should help
http://www.corvettemagazine.com/2001...handle/dh1.asp
Old Apr 10, 2007 | 06:56 AM
curtis74's Avatar
curtis74
Hey, that sounds familiar
Old Apr 10, 2007 | 10:07 AM
WVR 75's Avatar
WVR 75
DEMONSVETTE,
Thanks for that link. Pictures can make job
go smoother.
Nice collection. Visited my sister in Mililani in
February 06.
William
Old Jul 10, 2007 | 09:16 AM
HUSKER-Z's Avatar
HUSKER-Z
Guys,
Last night I opened up my driver's side door, and the handle broke off also. It looks like just the metal of the handle became brittle and snapped. Will I need to go through the whole process of above? Or just order the handle (the broken part) and replace it? Hopefully not the mechanism thing?? thanks...
Dave
Old Jul 10, 2007 | 05:12 PM
Durango_Boy
Originally Posted by huskergto
Guys,
Dave
You'll need a new handle for sure and I don't think you'll be able to replace the handle with the panel in place.
To Replace 75 Door handle opening control
