72 Tail Light Question
Old Apr 17, 2007 | 10:02 AM
Doug 61's Avatar
Doug 61
Default 72 Tail Light Question
Does anyone know if the inner and outer tail light lenses can be swapped over?
I've just bought my first vette, Now I just have to wait 2-3 months for it to get here . My problem is that over here the car must have amber rear indicators. What I was thinking about doing is swapping the lenses and changing the wiring to make the reverse light into the indicator(amber bulb), and having the stop/tail light work on the inner tail light.
Would appreciate any info or suggestions.
Cheers, Doug
Old Apr 17, 2007 | 10:54 AM
lowbuck72's Avatar
lowbuck72
yes, lenses are interchangeable, some guys, get rid of the backup lights and run 4 tailights.
Old Apr 17, 2007 | 08:52 PM
CoolShark's Avatar
CoolShark
I had the same problem on the Isle of Man. Paint the back-up clear portion of the inside lneses amber and wire them as your indicators. Then disconnect the old indicator wires.
Old Apr 18, 2007 | 04:50 AM
Doug 61's Avatar
Doug 61
Thanks guys.
Doug
Old Apr 18, 2007 | 10:12 PM
AB73's Avatar
AB73
I need to do the same thing on my 73BB for registration in Vic, any suggestions on what to do with the wiring loom to separate the indicators from the stop lights. Or is it simpler to run a new circuit for the indicators and just remove the old indicator wires from the stop lights?
Cheers
Tony
Old Apr 19, 2007 | 09:28 AM
Doug 61's Avatar
Doug 61
My car won't be here for a couple of months, so I'm not sure how I'm going to change the wiring yet. It will depend on where, and how the wires connect. If you're not familiar with wiring, get a sparky to have a look.
Doug
Old Apr 19, 2007 | 01:26 PM
7T1vette's Avatar
7T1vette
Swap the wiring and lenses...but I would choose to put amber blubs in them rather than to alter the lenses. [Just my $.02.]
Old Apr 20, 2007 | 06:26 AM
Bluey's Avatar
Bluey
Hi Doug. I have not long finished changing mine to get a roadworthy. There is another forum member from Aus who is very switched on. He has done a few of these and he emailed me a schematic on the easiest way to do this job. I followed it and it works great.
PM me if you want me to send you the schematic. Rgds Mark
Old Apr 20, 2007 | 07:23 AM
Chris Farrer's Avatar
Chris Farrer
Are you going for full registration or Special Interest. My '72 BB is registered for Special Interest in Tassie (52 days a year). Cars 30 years and older with the SI registration can have all the original tail light lenses. It is also staying LH drive.
Old Apr 20, 2007 | 08:04 AM
Doug 61's Avatar
Doug 61
Thanks Mark, sent you a pm.
Chris, I'm leaving it LHD. I would like full rego, even if it means making changes. When the car eventually gets here, it's going to be hard to get my butt out of it.
Doug
To 72 Tail Light Question
