'77 Seat Help!!!
Old Apr 18, 2007 | 07:13 PM
eepinnc's Avatar
eepinnc
1st Gear
Default '77 Seat Help!!!
I have a '77 that I just bought. The seats lean back too far. I tried replacing the seat bumper and bumper bolt. They won't line up correctly. It's like the seat is bent or something. Help!!
Thanks,
Ed
Last edited by eepinnc; Apr 18, 2007 at 07:20 PM. Reason: Wrong forum should be in C3
Old Apr 18, 2007 | 07:39 PM
SIXFOOTER's Avatar
SIXFOOTER
could be seat frame bent or broken. Take off the cover and check it out
Old Apr 18, 2007 | 10:20 PM
noonie's Avatar
noonie
Common problem, especially if larger or very tall people have owned the car.
The bolts you refer to are threaded into nuts that are spot welded onto a thin metal "u" shaped frame.
This shape easily bends out of shape over the years.
The seat tracks also can break at the floor mounts and or rust thru.
Take the pass seat out first to get familiar, it's easiest to take the covers off, rebend the metal with large channel locks to line up the bolts properly. There are a lot of poor factory mig welds. Then weld the poor oem welds and also the spot welded nuts. Test the fit of the adj bolts before welding and replacing cover.
Old Apr 19, 2007 | 06:54 AM
hot77rod's Avatar
hot77rod
Last year I completely redid the seets in my 77. Striped them down, removed all rust, repainted, replaced foam, new leathers. I found no obvious issues with the seat frame at all. It went very smooth and then when they were all back together I have the same issue as you described.
I plan to take them back out to see if maybe it was just the way I bolted them down. I have very little free time, so I decided it would just have to do for now. It still looks much better to me!
Let me know what you find.
I have more fun when I am the only one in the car anyway!
Old Apr 19, 2007 | 07:11 AM
noonie's Avatar
noonie
Shame you didn't check the alignment while they were stripped.
Old Apr 19, 2007 | 10:24 AM
Artsvette73's Avatar
Artsvette73
It's my guess the lower frames are cracked and a renforcement plate is available. Sometimes it is the seat back adjuster nut has let go but that is obvious to see. I have done this to my 73 and 77. If you have acess to a mig it's time to tear down the seats and rebuild them.
Old Apr 19, 2007 | 11:40 AM
TortureTest's Avatar
TortureTest
My guess is a little more simple. Yet probable.
This will be tough to explain without pics, but here goes !
With your seat installed and forward retracted you should see two "landing bolts" that are adjustable.....what these do is prevent the seat from going back too far. What these do is butt up against two similar flattend sections underneath the rear retractable section of your seat assembly.
My guess is that they are gone or minimally adjusted all the way down.
Old Apr 19, 2007 | 11:49 AM
noonie's Avatar
noonie
Thanks,
Ed
I think he said he is already past that.
Old Apr 19, 2007 | 12:59 PM
7T1vette's Avatar
7T1vette
If your seat frames are not damaged, I'm guessing that you are not a "tall" person [me neither]. The C3 seats were designed more "laid back" than prior or later years because that would allow enough head room for tall drivers. When I did my interior, I put 1/2" spacers under the back bolt areas (had to buy longer bolts, too). Worked out just fine for me.
To '77 Seat Help!!!
