while disassembling my 69 I copied the engine #s and looked them up in Richard Prince's Corvette restoration guide, what I found was a little confusing...can someone explain this to me??
the engine is supposed to be a 350\300.
the #s are 3970010...which states its a late 350
the intake manifold # is 346250...I couldn't find it...
the exhaust manifold # left: 384559...1970- early 350/300-350/350
Right: 3932461...1973-74- 350...
If the #s were correct, wouldn't they all be within the 68-69 era?
Post the numbers off the pad at the front of the right head. The engine stamp will identify the engine you have and it's original application. You should also find a VIN derivative stamp on the pad which will identify the vehicle the engine was originally installed in.
the tranny was rebuilt and its a m-22.
The 3970010 is not the date stamp and was used in verious applications. On the opposite side of the block is the date stamp and like everyone said list the # on the front pad..
WHOOPS , my bad Gordon,I meant to put down m-20...these are the # there: POP23A...
there's another #stamped beside it: 2 OP1 773 03...whats that mean?
OK guys, thanks for helping me out here...here are the important #s. I've suspected the motor wasn't original...is it? its very close to the vin
19S723516...and...V0619HY
19S723516...and...V0619HY...VIN is 194379S723516
