Can anyone provide some advice on the best method to attach a wrench to the #2 & #3 body mounts? I'm getting things ready to pull the body off and from the looks of it, the #2 & #3 mounts will be a PITA.
I used a socket, short extension, and a breaker bar. I found the #2 and #3 body mount bolts were the easiest to remove in comparison to the #4 mount! Good Luck
Impact socket and breaker bar. My #4 were so bad I just cut the bolts with a cutoff wheel.
One of my #2 had rusted enough the bolt head was a smaller size, found a metric impact socket fit perfectly.
One of my #3's was spinning the nut in its cage so I made cross cuts on the bolt head and finished off with 2 hits with a chisel.
Once the body is off I repaired all the mounts, replaced the cage nuts.
