I recently purchased a 1970 convertable, big block, 4 speed. It was suggested to me that my block may be a restamp based upon the difference between the block casting date of Aug 1969 and the car's production date of June 1970. There are also some pretty obvious grind marks under the right side of the serial number.
I understand that there was a delay in production that year and that 1970 cars were first made in January of 70 rather that September of 69. The block couldn't be for a 69 car because the 454 first came out in the 1970 models. Does anyone have any knowledge about the delayed production and when the blocks were first cast for the 1970 cars?
I'm also concerned about the grind marks. Every other number and production date on the car matches up. It doesn't look to me like there was an intent to decieve because the grind marks are very obvious. If someone wants to fake a block, you would think that they would do a much better job. Is there any way to find out if this happened at the factory?
...block casting date of Aug 1969 and the car's production date of June 1970....Does anyone have any knowledge about the delayed production and when the blocks were first cast for the 1970 cars?...
Post some pix of the engine pad. Engines were changed at St. Louis and blocks were restamped, but a time lag of August 69 to June 1970 isn't likely. That period is almost a year. Just the same, it cannot be discounted as a possibility.
Assembled engines were shipped to St. Louis on an average of two weeks (sometimes longer) before the car was assembled. As an example, the engine in my '68 was assembled on April 9, 1968. The time build code on the car is Saturday, April 20th. Eleven days. The block casting date is April 4th.
If '70 did not begin until the latter half of January, the first engines could have been assembled at the beginning of the month, then shipped to St. Louis. Casting dates could be very late December, 1969, or early January 1970.
From: PHOENIX AZ. WHAT A MAN WON"T SPEND TO GIVE HIS ASS A RIDE
Block casting # should be 3963512. It was on the back of the block. I am sure that your block is a 427. the 1970 Vet /454 CI did not come out till FEb. 1970. Blocks were the same bore but thay were strocked.SORRY KEN
I can't imagine verifying that something odd happened at the factory 37years ago without some existing documentation. However, I really would find it very hard to believe a 1970 motor coulod be correct with a casting date of August, '69 a time period when the previous year model was still being produced. Do you have the block number?
Regarding this progression and the OP's original question, it sounds like a pretty tight time frame. Do you think this is typical? Your car's engine casting date is 16 days before the car's final assembly. I know of cars with block casting dates 2 (or more) months before the eventual VIN/birthday of the car which are considered pretty acceptable.
Actually, typing while thinking is probably not best. I think the guidelines are about 10 days to about 8 weeks, making Mike's '68 just right as well as other cars I was thinking of that have an 8 week spread.
What's OK? 10 weeks? 12? What's too long a period?
Reason: answered my own question
3963512 castings on blocks were used for both late '69 production 427's and '70 production for 454's. You would need to pull the oil pan and look to see if the cylinder bores have the reliefs to clear the crankshaft.
The late 512 blocks were 454's and could be "right", just as a 321 block can be right on a late 67.
When was the strike?
BTW what is the date of engine assy? The TO number?
Thank you, everyone, for the input. You've been a big help. To answer some of your questions, it is a 512 block with reliefs in the cylinder bores. The casting date is "H 20 9", which I'm reading as August 20, 1969. The pad number is "T0608CZU", which I'm reading as Tonawanda, June 8th, 454/390 4 speed. It's a June 1970 car as per the door sticker. The heads and exhaust manifolds were cast in May of 1970.
Are there any other numbers inside the block, on the crank, rods, pistons, etc. that would help to authenticate the motor? The 4" stroke verifies that it's a 454. Are there any markings to match the crank to the block?
What about cast in Aug 1969, and then machined and assembled by June 9 1970? Its a Monday. A long time for a block to sit around, but they may have wanted to get rid of those 512's once and for all.
Blocks cast in Aug '69 could have sat around for 6-8 months with the 1970 GM strike. They would have been "in-plant" in August and the strike started in September. Plants were shut down at that point, and there was no production until March or April. It would have taken time to "ramp up" production, and [back then] there was no "first-in; first-out" stock inventory system. I believe it is quite possible that your engine is original to the car.
7LT1, I would need to respectfully disagree. The chances of a block "sitting around" for nearly a year, even with a strike (which I do not believe lasted that long although am away from my research material at the time so I can't be sure), and crossing over to the following year production would need to be measured in scientific notation. In other words, it didn't happen.
I agree with those above as to the block sitting around for a year does sound suspect. Also, I hate to say this, but you have a very desireable car and people are faking them all the time. As with the 67 BB's, there are now more on the road than were ever produced. The grind marks would be a dead giveaway to me. That car is worth far more as a numbers matching then not. If you just got it then it looks like even with the grind marks they got away with it. There are more faked blocks out there because the money is what it's about now. Without seeing it, I would say it's a correct block for the car but not the original.
I agree that in this threads case, there is cause for concern that doubt of OEM exists for whatever reason, others may disagree but the time gap does not give confidence, unless others have date gap examples around the same time period for the particular engine model.
I'm thinking the numbers matching thing is likely to get out of hand, driven by commercial value. This leads one to think, that unless there is something done to prevent it, I'm picking, there will be a company, probably Asian, able to produce a "numbers matching" block or heads, with date codes to order and stampings no one could tell from the original without detailed forensic science. They could do this legally by gaining a licence to produce these as restoration parts, the same way that companies produce replacement classic car parts.
It would be scary If that happens, what credence will there be to any supposed no's matching cars?
As to the argument whether its against fraud law, the foundry could hide behind customer demand technocality.
Any agrieved parties would then be forced into a "prove that it isn't OEM" strategy for proof.
