Rear wheel bearings
I have done a lot and want to keep getting "smarter" about this car, so if it is something that can be done right, the first time, by a rookie, then I am all for LEARNING it.
I've got some pictures on my website that may give some additional info. Scroll to the bottom half of the page.
http://www.corvette-restoration.com/trailing_arms.htm
http://forums.corvetteforum.com/show...earing+rebuild
We removed the spindle with a slide hammer puller, that was the easy part. The inner rollers fell right out. Remember that if you think you have a bad bearing! He had built a special tool which not only allowed reassembly without removing the trailing arm, but pulled the spindle back together with the help of a port-a-pack pump.
If not for him, I would have sent the T/A's to Gary(GTR1999), who I also sought advice through the process and he gave me great tips.
My advice...
1)Determine if the problem IS the bearings.
2)If it is and you don't have the tools or experience, make sure the person who does the job has done it before or does vette work professionally.
3)It costs a lot less to do it right the first time.
Good Luck!
Alignment shops usually check for loose wheels, which is a good thing, however on a vette rear, you cannot check the rear bearings by grabbing the wheel at the 6 o'clock and 12 o'clock positions.
If you do, you will be checking the end play of the stub axles in the rear housing. Some alignment shops that are not familiar with a vette rear setup will not know this.
Stub axle end play can be .030 to .130 end play, depending on wear.
You need to check the rear bearing play by grasping the wheel at the 3 o'clock and 9 o'clock positions and check for play.
Barry
