68 underbody
Old May 21, 2007 | 10:19 AM
76yellow's Avatar
76yellow
Default 68 underbody
I am doing my second frame off restore. This one is a 68 convertable. It appears that there might have been some sort of underbody insulation on the forward half of the body. There are many clips to hold something. Is anyone familiar with this ? I have it all cleaned up & ready to undercoat for looks & sound deadening which I did on a 73 recently. This is'nt going to be # matching so I'm not concerned about correctness. But if I can find a suitable substitute for whatever was there I would do it. Any help or suggestions will be great. Thanks
Old May 21, 2007 | 12:47 PM
waterplay's Avatar
waterplay
That was used to block exhaust heat. It was two metal shields (one on driver side one on pass) with an insulation like material between the fiberglass body and the metal sheet.
Old May 21, 2007 | 12:58 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
When the car was new, there was blanket insulation under there, held on by the clips. AIM shows it. If memory serves, ZIP has it if you want to replace it. Two pieces, a left and a right, foil backed fiberglass mat.
The clips are still in place on my '68 convertible, but the insulation is long gone.
Old May 22, 2007 | 07:41 PM
76yellow's Avatar
76yellow
Thanks guys.....I found it in my ZIP Catalog. I'm going to order it as long as all the clips are still in tact on the body. I figure the more heat & sound deadening the better. Right ?
Old May 23, 2007 | 01:04 AM
7T1vette's Avatar
7T1vette
I wouldn't put undercoating on the bottom side of the car, if it were me. There wasn't any on it originally, and if you went to sell it, could be a problem. You need to put a heat "blanket" under your carpeting; then you won't have cabin heat. The standard heat shielding and foil blanket are good things to do...and correct for the car. Also, I'm not sure what undercoating is designed for the heat your exhaust system is giving out under there; you may end up with unwanted vapors/fumes.
Old May 23, 2007 | 01:05 PM
68/70Vette's Avatar
68/70Vette
The clips are still available also. They are attached to the fiberglass with large soft rivets. Installation should be no problem if you have the body off.
You have to cut the insulation pads to fit into the car. The pads are insulation fiberglass sandwiched between an aluminum foil like material. The cuts will leave the fiberglass, a yellowish brown color, exposed. I bought aluminum foil adhesive "tape" and taped over the cuts to crate an all aluminum foil looking appearance. This also prevents oil and rode dirt from getting into the fiberglass insulation. Also, there's another part to buy, a foil lined insulation "sleave" that fits into the upper most part of the internal transmission tunnel. And finally you can buy a foam "horse shoe" collar that fits between transmission and tunnel to keep hot air from flowing into the top of the transmission tunnel.
Old Apr 25, 2009 | 01:36 AM
J.T's Avatar
J.T
6th Gear
if your 68 is like my 69 their is a two piece shield directly under each side --- a metal piece directly under each floor board with a plastic piece attached extending it up into the firewall --- under these shields is a insulation blanket with foil on one side --- I recently ordered from Ecklers the Drivers side insulation pad but now am having my own issue trying to figure out why it is wider than fits directly under these panels. good luck..
Old Apr 25, 2009 | 08:55 AM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
68 front shields are plastic and attach with rubber studs at the top and bolts at the bottom. Lower shields fiber board. Not sure how long these lasted after the first time you hit a rain storm, but my guess is not long. BTW - My early 68 shows no sign of under body shields, only the lower exhaust shields.
Old Oct 26, 2009 | 09:26 PM
kaiserbud's Avatar
kaiserbud
what are these you speak of..... you mean for side exhausts?
Old Oct 28, 2009 | 07:10 AM
kaiserbud's Avatar
kaiserbud
Budman - you must be talking about the aluminum wrapped insulation that is in the L shape.
But once mine is together, I was wondering if adding small aluminum shields to the side exhaust pipes right after the manifolds and before the side exhaust covers. ... but that's another subject.
76yellow.... I was going to use DEI Floor and Tunnel to cover the firewall and underside of the flooring... but reduced it to the trans tunnel only (for now at least) I will try to post pics when I can
Old Oct 29, 2009 | 10:53 AM
Easy Mike's Avatar
Easy Mike
...68 front shields are plastic and attach with rubber studs at the top and bolts at the bottom. Lower shields fiber board...
My lower shields are metal. April build date. They are probably original, but I couldn't swear to it.
Old Oct 30, 2009 | 10:27 AM
68 l79's Avatar
68 l79
Mine are too. June build date.
To 68 underbody
