Broken Hood Release Cable-Help!
Old Jun 1, 2007 | 08:06 PM
bogart8665's Avatar
bogart8665
Cruising
Default Broken Hood Release Cable-Help!
Anybody have a trick for getting the hood open after the hood release cable breaks? Help, I need to get in there.
Old Jun 1, 2007 | 10:06 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
A screwdriver through the emergency access holes "will work" but I made a simple tool for just in case. Check out
http://www.c3vr.com/forum/forum_posts.asp?tid=69153
Old Jun 1, 2007 | 10:07 PM
Durango_Boy's Avatar
Durango_Boy
In the wiper trough, there are two access holes going into the engine compartment just behind the hood latch locations. They may have plugs in them so just remove the plugs and using a long screw driver through the holes try to trip the latch. It may take some practice but you will get it.
Old Jun 1, 2007 | 10:34 PM
bogart8665's Avatar
bogart8665
Cruising
Default Right on!
Thank you very much!
Old Jun 1, 2007 | 10:48 PM
69camfrk's Avatar
69camfrk
From: GA "When I grow up, I'm gonna get a Trans Am and run from the cops". Direct quote from my 4yo son.
Hey Matt, I've been drinking so I say use a crow bar and a torch. Somethings got to give!
Old Jun 1, 2007 | 11:22 PM
kingkohlmn's Avatar
kingkohlmn
Veteran: Marine Corps
Follow the link, good luck.
http://www.madvet.com/shop?frame=3852
Old Jun 2, 2007 | 08:11 AM
Durango_Boy
I would put money on your balance giving out before the hood.
Old Jun 2, 2007 | 05:06 PM
Red 71's Avatar
Red 71
From: Melbourne, Fla. 6 months- New Middletown, Ohio 6 months
71 small block convert with AC built in Jan 71. (general info that may make a difference)
I have the hole with the plug on the passenger side but there is no hole on the drivers side. Anyone else that can verify the same on their 71. I have read once before about drilling a hole on the drivers side for access so I would guess that I am not the only one with this setup. Perhaps the change to two holes came after 71.
To Broken Hood Release Cable-Help!
