weak door....74
Old Jun 18, 2007 | 09:24 PM
pushin_400's Avatar
pushin_400
Default weak door....74
drivers door hinges are weak. when door is opended you can see where the hinges bolt to the pilar move and move the pilar with it, it seems..if you can picture that
any suggestions how to repair or what might be wrong, my garage is closed for reno's so i have to work at my house space is limited.
thanks steve
Old Jun 18, 2007 | 09:43 PM
LYLE's Avatar
LYLE
You must have bad bird cage rust. Remove the kick plate and look at the back side where the hinge bolts.
Old Jun 18, 2007 | 09:50 PM
corvette74's Avatar
corvette74
Steve I think you should check the rocker channels at the #2 body mount, sounds like they may have rotted away.
Dale
Old Jun 18, 2007 | 10:09 PM
aussiejohn's Avatar
aussiejohn
Default tin worm
Steve,
Sounds like you've got a severe case of tin worm in your birdcage. It's not going to be cheap to fix, but it CAN be fixed. There is an article on this in the current edition of either Corvette Fever or Vette. It involves substantial disassembly of the front fenders and firewall area but if repaired properly and RUSTPROOFED, will last almost forever. Don't give up on it, although you'll probably feel like it.
Regards from Down Under
aussiejohn
Old Jun 18, 2007 | 10:46 PM
SIXFOOTER's Avatar
SIXFOOTER
If the door Pillar is moving you have real structural issues in the birdcage. You could get lucky and it only be the bottom. Like mentioned above, it is a lot of dissasembly. Pull the kick panels and look in there. Its a comitment, a year or more if you work like me.
Old Jun 19, 2007 | 12:05 AM
pushin_400's Avatar
pushin_400
kick panels removed there is surface rust but nothing rotted through looks solid with some care
steve
Old Jun 19, 2007 | 09:27 AM
SIXFOOTER's Avatar
SIXFOOTER
Well, the only other place it can be broken loose then is at the top. I would pull the door and look at the door post itself, see what ya got there. It is supposed to be pretty stiff. There is an angle bracket at the bottom on the back side welded to the door post and rocker channel for strength. Its under the fiberglass sill plate though, hard to get a look at.
Old Jun 19, 2007 | 10:23 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Are you sure the pillar is moving? You said it "seemed" to move. Are the hinges tight? Bottom hinge bolts are behind the kick panel. Uppers are further up behind the dash pad but you might be able to get a wrench on them without pulling the dash.
Old Jun 19, 2007 | 05:22 PM
pushin_400's Avatar
pushin_400
its hard to tell sometimes it does, some times it doesnt pending how far i open the door.
if i open it slightly and let it hang, it doesnt seem like it moves, but the hinges seem weak.
if i open it all the way is where i see and get the idea the pilar or the piece the hinges are bolted are loose.
btw you think a good body shop can take care of this and how much you estimate...
p.s
rust found under the dash, small but there...its corner piece that connects the a-pilar from roof to dash??
all help and comments are greatly appreciated
thanks
steve
Old Jun 19, 2007 | 11:44 PM
pushin_400's Avatar
pushin_400
bump
Old Jun 19, 2007 | 11:48 PM
SIXFOOTER's Avatar
SIXFOOTER
No reason to go to the body shop yet. You can get to the hinge bolts, take them out 1 at a time, brushwheel off the rust, lube and reinstall them tight. It may just seem like the pillar is moving, hinge bushings may be done, I think the kit is $20.
Old Jun 19, 2007 | 11:54 PM
pushin_400's Avatar
pushin_400
ok this may help i did not mention that the door does not line up properly when closed, it sags abit, it closes but not aligned properly.
hangs down a bit...
steve
Old Jun 20, 2007 | 09:07 AM
pushin_400's Avatar
pushin_400
bump
Old Jun 20, 2007 | 09:28 AM
moosie982's Avatar
moosie982
My vote is for a worn hinge/bad bushings, check it out, try having someone more familiar with it look at it for you, you may wind up paying a lot of money if you take it to a body shop where they care about money more then a happy customer,,,Peace, Moosie
Old Jun 20, 2007 | 12:40 PM
c3 in hawaii's Avatar
c3 in hawaii
when I got my '68 I had to actually lift the rear of the door to get it to close, inspected the hinges...the lower had bad bushings, while the top was busted all together. replaced them both and now closes nicely with the door gaps correct.
Old Jun 20, 2007 | 12:47 PM
ccs96's Avatar
ccs96
St. Jude Donor 06-'07
Pics would help too.
Old Jun 20, 2007 | 03:41 PM
Easy Mike's Avatar
Easy Mike
Yep. Post some pics.
To weak door....74
Old Jun 20, 2007 | 04:02 PM
Glassbowtie77's Avatar
Glassbowtie77
Old Jun 20, 2007 | 04:44 PM
pushin_400's Avatar
pushin_400
i would love to post pics i dont know how to...
btw thanks for all the help appreciate it
steve
Old Jun 20, 2007 | 07:28 PM
pushin_400's Avatar
pushin_400
hold up BIG PROBLEM, ROAD BLOCK.
found the pilar from top of dash to floor (mount area) is badly rusted, rusted so bad its needs replacing...damn (shaking head) frustrated.
please shine some light on this, is this replacable if so how much u think a body shop would charge..
thanks need help
steve
