The $300 Stereo/CD upgrade.
The original kick panels, being available as after market reproductions, were used in the install to keep costs down.
Background:
I wanted to upgrade my 'Vette, while keeping costs down. (I got some cool CDs that will need to be played, once I complete the 'Vette upgrades- (esp. Barracuda, by Heart) Well, this is a serious situation.)
Method:
What I needed was a package to accomplish this goal. These had to be quality componants, and originality could not be sacrificed, not acceptable.
The Parts:
Reproduction Bezel: cost only $115, So I can save my original Bezel,, Corvette Central:
and
http://www.millionbuy.com/aifp306.html
Head Unit" $99,
I went to Circiut City and Listened to the 99-119 dollar units. the sony was tinny, the Pioneer really kicks ykw for the price, and looks good too. 25W a channel RMS. Pretty good in real world situations.
The Speakers: $49, they say 160W real big on the box,, but I geuss that's just when the sun spot are alligned correctly, because in the specs, and in smaller print on the box, they say 30W -continous,, that's RMS folks or Root mean square,, or real continous power, minute to minute. Perfect for the 25W a channel Pioneer dash unit.
Add 50' of 16 gauge speaker wire from Radio Shack at 10 bucks and 20 "red" butt splices from autozone at 2.99 for 10 and you get
115+99+49+15+10+6= $299. I made my target.
the Install:
Pulled the E-brake cover, then the shift consol and pulled the Enviromental switch. Cleaned it up really good, esp the Fan switch, which I ran WD 40 through 4 times as I worked the switch back and forth to get my fan to work on high speed again
One other thing to note, I noticed that on the back of the Hand Brake consul there is a bolt that goes through to inside of the rear three compartments space, below the "glove box" or tic tac case, as I like to call it. Mine was previously removed. It seems possible to remove the shift consol w/o removing the brake consol, and I would recomend it, unless your a gluton for punishment.
Switch:
Pulled the gauge bezel and pulled the old radio (free the radio from the bezel so you can remove the bezel at first). Be very carefull here if you have a 60s or early to mid 70s Car, as the OIL PRESSURE GUAGE USES A THIN PLASTIC FLEXABLE OIL TUBE FROM THE ENGINE. DO NOT BREAK OR KINK IT!!!
Ran the speaker wire and then used my handy red handle stripper/crimp tool the crimp the red butt splices to the speaker wires and the connector of the Pioneer head unit, and then ran a 14 gauge wire to the "Batt" terminal on the fuse box for the constant power it requires, butt spliced that in along with the ground (requires a Blue, larger butt splice) and the yellow for detection on: aka ACC. Done with the head unit:
Decided to reuse and not save the kick panels, they are widely available in correct color and my vette isn't an L88.
Measured the maximum height of the body mount hole and tranfered it to the kick panel with a sharpie. Cut the holes with a Dremmel tool disk below this line and centered, one small cut at a time and then smoothed the hole out with a sheet rock knife, Test fit the speakers, and THEN drilled the holes:
Installed the Speakers,, you have to install the kick panels first, then put the speakers in.
All that needs to be done is plug in the Head Unit and mount the kick panels. I also ran the rear speaker wires, Now, while the Concol is appart and will run a line level stub and bring out the blue controll wire, while it's appart. This Is Fun!
Waiting on the Bezel with my Dremel tool, but it's plug and play, Now.
Just check on Photobucket, Imove a pic of the sound bridge already - here is what it looks like installed:
I went with the Bridge because I did not have the back speaker grills, in retrospect I guess I should have looked harder for them at the time. This Bridge rides high enough on the back panel to still allow room for my T-Tops.
Yes, I did relize that, butr 115 is not 200. Check the title of the post as for why i didn't use a precut one. My dremel awaits.
Just a suggestion. When planning the rear speakers I would suggest 6.5" round speakers instead of oval 6x9" speakers. Round always sound better and are easier to install.
Oh, and that repro bezel was about $40 more than it needed to be.
I have been looking for a while now and 55 was the cheapest i could find. total was 70 inc shipping..
Now on the rear speakers what is the best way to mount to 6 1/2 ?? any pics ??
Well that all depends. You can make some panels that close the gap between the rear bulkhead and the wheel wells and install the speakers in those. Or, you can make a box that houses both of them.
Oh for '77. For some reason I was thinking you had a '73. I guess it was you're name with the 373.
Here are some CDT 6.5" speakers in kick panels. They had a very large magnet.
DB, that install looks good. Did you cut the existing kick panels or use the pre-shaped ones on that install?
I had no problem,, just put them in today. There seemed to be plenty of space back there. Don't know what may have caused your clearance problem,, were they too wide in diameter? well, they're in your are in the doors now, anyhow. Probably a better place for them anyhow.
Last edited by RunningMan373; Jul 19, 2007 at 11:58 PM. Reason: misspellings and other sudry errors. lol.
