Why does the hood sit high on front ?
Old Jul 21, 2007 | 05:57 PM
bj1k's Avatar
bj1k
Default Why does the hood sit high on front ?
I've seen this problem on C3's occasionally and have never been able to see what causes it. The hoods usually fit pretty good until you get down to the front, then they stick up as much as 1/2 inch across the front and there is no adjustment on the hinges. It looks to me like sag from the weight of the headlights on the header bar over the years. I'm running into this with my 68 and the front clip that I am using is off of a 69 . Has anyone ever ran into this before and how did you fix yours. It wouldn't be hard to build it up but I'm wondering what the cause is so it could be reversed. Anyone with this previous problem ?
Old Jul 21, 2007 | 06:03 PM
greg454's Avatar
greg454
Mine was perfectly flush untill I replaced the radiator top air dam. The new stiff foam now holds the front of my hood up a little.
Greg
Old Jul 21, 2007 | 06:41 PM
standup's Avatar
standup
Have you checked for shims under the hood hinges where they bolt to the fenders?
Old Jul 21, 2007 | 06:53 PM
Artsvette73's Avatar
Artsvette73
When the fender and hood surround are bonded together the inner fender skirt controls the for and aft and up and down of the hood. The skirt is bonded to the fender and once it is bonded, pretty much your adjustment is gone. Thats why it takes so long to fit these pieces together. Taking a clip form one car to another will not cure the problem. These cars were off so much in build tolerence that left alot to be desired.
Old Jul 21, 2007 | 06:59 PM
Z-man's Avatar
Z-man
Sometimes if you let a little air out of the front tires, that takes care of it...
Old Jul 21, 2007 | 07:22 PM
SmokinBBC's Avatar
SmokinBBC
Greg
Same here.
Old Jul 21, 2007 | 09:22 PM
CCrane65's Avatar
CCrane65
I put an Air Ride hood hinge suspension under mine and now my hood goes up and down like a low rider!
cc
Old Jul 21, 2007 | 10:26 PM
bj1k's Avatar
bj1k
cc
Bubba has become a comedian now !
Old Jul 21, 2007 | 10:39 PM
big_G's Avatar
big_G
The front 'glass has sagged. That is why you see G.M. added header support brackets in '69. Probably what happened is someone had the bumper support braces loose and the 'glass weight malformed the f'glass over time. If you have time and are brave you can remove all support braces and slowly over time bring the f'glass front end up into correct position.
Old Jul 21, 2007 | 10:44 PM
Michel B's Avatar
Michel B
From: Ville de la Baie Quebec. A winner is just a loser who tried again.
I ended up cutting slits in the curved portion of the hood chanels to follow the contour of the car. after glassing it all were i wanted, it fits perfectly.
Old Jul 21, 2007 | 10:55 PM
Jc3vette's Avatar
Jc3vette
I had the same problem with my hood. I was able to adjust the surround and the whole fiberglass front end up. By adjusting the surround support, the nose support, the radiator support, the front bumper brace arms and the extension arm.
What got me started looking at the different brace adjustments was,
When I had this problem I received this reply from Easy Mike.
First question: Are you running the stock hood? You may need to raise the hood surround panel to meet the hood lines. There should be two reinforcements on the front of the inner fender skirts which bolt to the header bar. They will be illustrated in the AIM. There should also be a bar or bracket behind the bumper which will raise/lower the nose.
In a worst case scenario, you might have shim under the radiator support.
I had a similar fit problem on my '68. I raised the nose and solved the problem.
Old Jul 22, 2007 | 09:08 AM
SULLY_PA's Avatar
SULLY_PA
Old Aug 15, 2007 | 10:54 AM
Overlord's Avatar
Overlord
From: Crush your enemies, see them driven before you, and hear the lamentations of the women TX
Going to have to give this a try. I'm cutting down a set of hinges to try and meet the panels ½ way. I'd bring it down farther but the hood would be resting on the top radiator brackets.
Old Aug 15, 2007 | 11:40 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Those help considerably. I added a pair to my '68. You should also find a rod from the lower radiator support to the snout of the nose.
Old Aug 15, 2007 | 05:35 PM
Overlord's Avatar
Overlord
Thankee kindly.
I'll have to take a look at the AIM when I get back into town and get a better idea of what those are doing in there. More of a 3d image in my head.
Old Aug 15, 2007 | 06:25 PM
spedaleden's Avatar
spedaleden
My 80 looked like this
It is caused by collision and then poor bodywork for the repair
Old Aug 15, 2007 | 08:28 PM
James.70's Avatar
James.70
From: Show me a cold beer and I will show you a happy man Maryland
That is what is wrong with my front end except I have the opposite, the hood is lower than the nose...and the head lights are also below the nose . You can see the bad repair and there is cracks on the upper inside corners of both headlight holes.
To Why does the hood sit high on front ?
Old Aug 15, 2007 | 10:13 PM
spedaleden's Avatar
spedaleden
The only way to fix it right. Is to find a good body shop. It is going to be expensive.
Old Aug 16, 2007 | 08:31 AM
Edzred72's Avatar
Edzred72
My 72 was this way when I bought it. The fiberglass on the nose broke free from upper metal header support. (just above the vac actuators) Once that was bonded together again...hood & headlight doors fit great!!!
Eddie
Old Aug 17, 2007 | 06:16 AM
James.70's Avatar
James.70
Yeah, I figured but it is cosmetic and will be done after all mech work. I will have all the paint stripped body work done and new paint dead last so I dont mess it up. It is a 15 foot paint job and looks ok for now.
Eddie
Thanks for the tip!! I am going to check that out.
