What I need is something I can use where the wiring bundles either go through the firewall or where they meet in a three or four way junction. I don't want to use zip ties or tape and was hoping for some kind of plastic clippable joint that cleans everything up.
Check Summit, they carry the corrugated plastic loom and joints, The joints will work with that stuff. But what I have done on larger equipment I have built useing that stuff, you can just overlap the pieces, for a T you can push the smaller branch and continuation side inside the large side and secure with a tie wrap. It makes a nice neat low bulk joint
