12.99 HL Switch dimmer repair.- Part of our 'Vett on a budget series...
The reason for wanting to change the switch was the dimmer didn't work. Well, that's the wire wound taped res in the front of the switch.
I pulled the old switch today, and on getting home from work took it apart along with the new wells switch.
Here was the problem:
The wells switch is a dead on copy of the GM, however- sans the Vac switch.
It just so happens that the Wells Ceramic front with the Wire wound Res fits the Original GM almost perfectly.
So I swaped the ceramic parts and cleaned up, the copper switch surfaces, spread Electrical grease on the terminals and put it all back together.
The end result is ready to roll, and at 12.99, cheaper then a $60 new switch.
I am heading to my local Autozone today to pickup an SW141. I went to Wells web-site and found that they list this as a replacment headlamp switch for Corvettes (It does say Corvettes without retractable headlight though ).
SW141 Headlight Switch Exc. w/Retractable Headlight Covers
You'll have to slightly notch the front inside hole to get it to fit the new ceramic piece. ~1mm, each side, can barely see it in the last big top pic, C.
Location: Crush your enemies, see them driven before you, and hear the lamentations of the women TX
what happens is the bend on the contact arm is pushed up by a bump on the front plactic barrel of the switch on rotation and makes contact with the top metal housing of the switch, which is grounded. acts like another of the contact switches. It's the far side lug.
I put mine together last night. I didn't have to notch the cover as you did though. The only thing I see is different between the two switches is the vacuum port (of course) and the internal contact assembly on the new switch didn't have the slot for the vacuum switch lever to go into. No big deal, I used all of my old switch execpt for the dimmer resister. I owe you a beer with the $50 I saved.
Has anyone who has replaced their headlight switch, either this way or by replacing the entire assembly, noticed brighter dash lights? I did mine a while back and was disappointed by the lack of brightness.
Wish I knew this a month ago. The coil was shot in several spots.I just took mine apart and jumped it with a wire attached to a pair of super fine machine nuts and bolts. They wont dim, only come on and off now when they are in the full bright position as before, but now they do shine brighter.
I replaced the headlight switch and EVERY bulb in the car and still not very bright. They couldn't possibly have been that dim when the car was new.
