staggered setup
Old Aug 1, 2007 | 10:24 AM
HUSKER-Z's Avatar
HUSKER-Z
Default staggered setup
How do you think this sounds?
I've got a 1976:
On the rear 255/60-15
On the front 235/60-15
BF Goodrich Ratial T/A's
Anyone do a staggered setup? Whatcha think?
Old Aug 1, 2007 | 11:37 AM
hotshot79's Avatar
hotshot79
I have 235-60-15's on front and 275-50-15's on the rear. works fine.
Old Aug 1, 2007 | 12:18 PM
Tim H's Avatar
Tim H
235s are too small.
Its just not worth staggering , going that close in size, you might as well just go 245/60s or 225/70s all the way around so you can rotate.
Old Aug 1, 2007 | 02:01 PM
HUSKER-Z's Avatar
HUSKER-Z
Hmmm...
what's the biggest difference between 225-70's and 245-60's? I'm looking for (at the bare minimum) a wide tire look in the back.
thanks!
Old Aug 1, 2007 | 06:27 PM
Star79's Avatar
Star79
I've got a 1976:
Exactly my setup, same tires same sizes. Visually it's hard to see a difference, but when I had 255s on the front they rubbed on tight turns. Also the car seems to track better with the slightly skinnier tires in the front. When I get around to replacing the rear it'll be 275s back there and the rake/stagger will be more noticeable.
Here's a pic:
Old Aug 2, 2007 | 09:10 AM
sxr6's Avatar
sxr6
Yep that's my set-up, 255x60 rear & 235x60 front. Looks perfect, you can hardly see the diff in height & just slightly narrower. I had the 255x60 BFGs on the front but found it scrubbed the frame & made the car track road surface undulations. It drives hugely better now with 235s on the front
Old Aug 2, 2007 | 09:20 AM
HUSKER-Z's Avatar
HUSKER-Z
Would I have to do any modifications to go 275/60-15 in the back instead of the 255?
Old Aug 2, 2007 | 09:27 AM
Jims79's Avatar
Jims79
Originally Posted by Tim H
235s are too small.
235's are too small, I have 245/60's front & 255/60's rear
Old Aug 2, 2007 | 10:36 AM
70 LS1's Avatar
70 LS1
Staggering looks good. Personally I like the staggered wheel look as well.
First pic 235/60/15 and 255/60/15
Second pic 245/45/17 and 275/40/18
Old Aug 16, 2007 | 12:08 AM
HUSKER-Z's Avatar
HUSKER-Z
Great pix and advice folks! Thanks!!! I ended up going 225-70 15 in front, and 255-60 15 in back. Seems to work just fine!!! I'll post some pix up when I can get my camera here!
Old Aug 16, 2007 | 04:43 PM
ragtag74's Avatar
ragtag74
Default ragtag74
I run 275/60/15 rear and 255/60/15 front ,offset trailing arms . No rubs any were. John
Old Aug 17, 2007 | 01:54 AM
miechesa's Avatar
miechesa
295x35/18 rear 255x45/17 front
To staggered setup
