Need help testing MSD electronic ignition
He is correct, there should be a yellow cloth sleeved wire from the solinoid to the + lead of the coil. It will supply +12v to the coil during cranking, as stated. Better check the wiring to the MSD, and check to make sure that it's correct, and that a resistance wire is used with it. If not, you'll have to run a bypass. The resistance wire should read about 1.35 Ohms and is from the bulkhead connector in the engine compartment to + lead of the coil. The second bypass wire is from the soliniod to the + lead of the coil. this is from a '73,, yours should be simliar. Incedently, if you remove the resistance wire from the coil it should read +12V, free. Also check your engine to frame ground cable, and batt to frame ground cable, and main Batt + cable.
Incedently, the two main front hanresses may have smoked, but they have to get their current from somewhere. besides the main batt hook up at the horn relay, they also get it from is the main interoir harness. If your fronts fried, then I would take a really good look at the interior main harness wiring, for melted insulation.
TROUBLESHOOTING
Every MSD Ignition undergoes numerous quality control checks including a four hour burn-in test. If you experience a problem with your MSD, our research has shown that the majority of problems are due to improper installation or poor connections.
The Troubleshooting section has several checks and tests you can perform to ensure proper installation and operation of the MSD. If you have any questions concerning your MSD, call our Customer Support Department at (915) 855-7123, 8 - 5 mountain time.
LED
The LED on the side of the MSD monitors several operating conditions of the MSD. If the LED indicates that there is a problem with the ignition system, follow the steps through the Troubleshooting section. The LED will appear to be on steady at above idle speeds when everything is functioning properly.
• Flashes once per second if the battery supply voltage is low when under 3,300 rpm (while
multiple sparking). This indicates a charging problem or poor connection.
• It will flash approximately once per second if the battery input voltage is above 27 volts for
a sustained amount of time.
• The LED will flash for every trigger signal from the distributor or crank trigger. You can take
advantage of this when statically setting the timing when using the White wire to trigger.
http://www.msdignition.com/downld1.htm
100%
