How hard is it to install carpet in 1977 corvette
Senior Member
Received 2,031 Likes
St. Jude Donor '10
The key is warmth. If it is cold then this might be tougher. Do you have a warm place you can put the car for a couple of hours and or a space heater you can use to heat up the area safely? Mine laid out nicely one I sat her in the sun for a few hours one Saturday before install, then she fell in like butter. Let us know and we'll do our best to help.
David
77Sleeper
I pulled them out on my 76, did some welding on the rusted floor pans and placed them back in. If you have the formed type of carpet they just like slid right in. Realy easy and I am only 16.
this is molded carpet and it is wrinkled all around the storage doors. I was just wondering if anyone had had this problem and was it because it is cold. Perhaps it will sort out when the weather warms up. it has been about 12 degrees outside. and I am 51
Senior Member
St. Jude Donor '10
I would think it might be adhessive isn't holding it down, or that is what it looks like to me. I am 55 and can tell you my garage and I don't see a lot of each other now that the temps are well below freezing. I pray a lot for an early spring.
After I had installed the side and back T panels panels I put the storage compartment back down to check the fit. It bunched up. I did a little trimming around the storage compartment to get a good finish between the carpet and the compartment. I do remember the carpet wanting to bunch on the sides of the compartment just about where yours is in the picture. I just made sure they were glued down and then used the storage compartment frame to get the carpet not to pinch too much against the frame. No rolling over here, the top trim of the storage frame will go over the carpet. If your carpet extends too far inside the hole where you frame goes it may try to push it back out and cause wrinkles or bunching.
I would try removing your storage compartment top frame and work with the carpet to lay down using adhessive and trimming to match the opening. Once it is lying down smoothly with the adhessive bonded you should be good to put the frame back and should be good to go.
I hope this helps.
Best of success.
David
77Sleeper
I hope this helps.
Best of success.
David
77Sleeper
Senior Member
St. Jude Donor '10
carpet
Attachment 47633504
Front carpets were very easy to install, just measure twice, cut once around the seat belt area and take lots of pictures as you pull the old carpet.
Attachment 47633505
Interior as it was nearing completion.
Attachment 47633506
Added the speaker box to the rear to complete the install of carpet and sound.
Attachment 47633507
Came out pretty good. If you have any questions shoot me a PM, be glad to share more.
Best regards and enjoy,
David
77Sleeper
Attachment 47633505
Attachment 47633506
Attachment 47633507
David
77Sleeper
thanks,
Mike
Sig1977
As others have said buy from Al Knoch.
Tip: Before installing, let the carpet sit out in the sun to get warm and plyable before you start. It makes it much easier.
Additionally, i had to drill out the screws holding the sill plates and then had to re-tap the holes. No biggie, just another PITA in the restoration process....
Cant overstate this. My car came with some CHEAP replacement carpet.... every time I remove one of the seats, I tear the carpet. Accidentally drop a screwdriver in the footwell and jam into it with your foot....more tears. Avoid the cheap shi+.
can someone post a pic on how then did their front carpet with the retractor seat belt. Should I cut a line in the carpet can pull the belt through? Im just starting my carpet install and im not sure what to do with this area. Ill be happy to post pics of where I am so far.
#34
Thanks for the video. my 73 has the retractor seatbelt mechanism under the seat. then the belt has to run through the carpet. I have seen some that put the plastic protector box for the seatbelt over the carpet. If I don't do this...how do people run the belts though the carpet.
#36
Changing the carpet in my ‘73 was a miserable task... I used an ACC “GM replacement” brand kit and it was awful. I eventually got it installed and it looks pretty good but.. finally had to give up on the wheel arches in the back as the molded carpet was no where close to correct. I ended up using a black fleece material on the wheel arches and it looks great now.
Itll be a long time (as in never) before I change the carpet in my C3 again. mardyn
#37
Thanks to all of you for answering and especially for the tips! I'll give it a good cleaning first but I'm pretty sure it will need replacing. Thanks again and I hope you're still enjoying a happy Thanksgiving.
