I am assuming you are asking about the blower motor switch for your HVAC system?????????????
Remove the side console strip on the drivers side then remove the two hex head screws that hold it to your HVAC controls and install the new one. Obviously you will also remove the wiring from it also.
Plug in your new switch BEFORE you do this to make sure it fixes your problem.
