Hey Guys..... I need some help.
I am in the process of finishing the restoration of my 71 LT-1 Vette.
I had all of the chrome redone. Are the egg crates in the front painted black inside the crates?
I certainly would like to thank everyone in advanc for their responses.
This forum is the BEST!!!
No. The egg crates [on the front grilles] are not painted black. The front edges are left chrome; the remainder of the grilles are painted a "cast iron gray" color. If you are doing an NCRS-correct redo, you need to get the exact paint formula and have it mixed by a pro paint shop. If you are doing it for looking new and very close to original, go to your local auto parts store and find a "cast iron gray" paint. The real trick is the masking of the chrome. Most folks choose to paint the whole grille area and peel off the fresh (unhardened) paint with an X-acto knife or razor blade. Handling the grilles to do that with fresh paint is a challenge. Also note that the inside edges of the surrounding chrome pieces are painted the cast iron gray color, as well. [Check some of your Corvette history books for the correct layout if you are not sure; or go to Barnes & Nobles to look at one.]
The color is the same as the bumperette's I believe. I just got the correct paint code for PPG paint, and it was a perfect match. The PPG number is DDL32939 Acrylic Lacquer Silver Gray.
Don't try to use masking tape.....use Vaseline!! yes, vaseline. Wipe a little bit on the chrome front and then paint. Just wipe it off when paint has dried. With a little practice and some q-tips (for cleaning up the corners and getting too much on) you should be able to wipe the whole thing in a couple of minutes. Use a q-tip dipped in solvent to take care of any of the spots that have paint that shouldn't....
If I remember correctly, the center grilles were just painted black. I don't know why....I thought they should be the same as the side grilles. But they are just pot metal without chrome and painted kind of a semi-flat black. If you still have a center grille on a '70-'72, protect it...you can't buy replacements (only old originals on e-Bay for $$$$).
You could be right... but I've never seen the center grille painted anything other than black. I think we need an NCRS "referee" to the rescue. Can someone "make the call"?
I would like to thank everyone who responded for their help and input. 7T1, love the car!
If I could figure out how to post pics I would like to show some of the during and after pics.
Thanks again, you guys are the best!
Not sure why you would doubt my answer. Have 2 original paint '71's and have owned 3 '70's, 3 '71's & 2 '72's. Joined NCRS in 1987 and have top flighted cars at national, regional & chapter level events.
As I said..."I could be wrong"...and apparently I was. No need to be "testy".
I thought my response to your inquiry was quite civil. You asked for a NCRS referee or someone to make a call. I listed what I thought would help validate my answer.
Sorry to post on an old thread, but this one was helpful. I am still having trouble finding somewhere to buy cast iron grey paint. I have tried automotive, hardware and paint stores and nobody has any. Does anyone know where to buy some?
Hi ls,
If you're asking about cast iron gray for your grills I believe you'll find it's too light a gray.
Many people feel that the paint from EASTWOOD known as Zinc Phosphate is quite close in color and texture to what was used originally.
It's 10281Z.
They also have cast iron gray if you decide to use that.If you order it you'll have it in a couple of days.
Regards,
Alan
