Paint Help
Old Sep 11, 2007 | 04:46 PM
dirtyslumlord's Avatar
dirtyslumlord
Default Paint Help
The paint on my 79 is in, err, "original condition" - meaning it is almost 30 years old, faded, with a couple of smaller bubbles, etc.
I am planning on having it stripped and repainted in a few years, but right now I have just dumped all my money and time into replacing the motor (zz383 -should be running in two weeks!), suspension, brakes, rear end, radiator, ac/heat, blah, blah, blah.
So my question is, is there anything I can do, for few hundred bucks or so, to make the paint a little better? At this point, I am even afraid of waxing it. Has anyone had any success with a good detailing? Any other ideas?
Old Sep 11, 2007 | 06:52 PM
Blue Seducer's Avatar
Blue Seducer
Old Sep 11, 2007 | 07:11 PM
7T1vette's Avatar
7T1vette
Take it to a good paint guy who works on Corvettes a lot. He'll tell you what can be done. If the paint is not breaking down (checked, split, etc.) a good cut-n-buff will do wonders for the paint. Then you [or the painter] can do some careful touch-up on chips, etc. and finally put on a good polymer glaze (rather than wax). You won't believe the difference (and it won't cost "an arm & a leg").
Old Sep 12, 2007 | 08:03 AM
dirtyslumlord
I am definately more of a engine guy, than a body guy.
When you say 'cut and buff' is that the same as waxing with a rough compound wax? Also, is the polymer spray equivalent to a clear coat?
Thanks for the tips!
Old Sep 12, 2007 | 09:32 AM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
A Porter Cable Orbital polisher will work wonders on tired paint.
http://www.adamspolishes.com/p-108-p...ssentials.aspx
Old Sep 12, 2007 | 10:14 AM
7T1vette's Avatar
7T1vette
A cut-n-buff is using a low speed electric polisher/buffer and some liquid [mild] abrasive compound to take off the oxidized layer of paint, to bring out the original color, and to smooth the surface [make it shine]. That gets the paint ready for its layer of protection. Many people still "wax" their car with their favorite brand/type of wax. That still works well; but the new polymer polishes are much easier to use, requiring much less effort, eliminating the "white dust" syndrome, not degrading in the sun/over time, and allowing you to add layers of the same polish without having to strip the first layer...and the more layers, the better the shine!
Old Sep 12, 2007 | 11:42 AM
427basketcase's Avatar
427basketcase
That's some good stuff there!
To Paint Help
