transmission
Old Sep 14, 2007 | 10:19 PM
Jpour's Avatar
Jpour
5th Gear
Default transmission
how much does it usually cost to rebuild the transmission(on a 1980)? maybe like a ballpark estimate?
thanks
Old Sep 14, 2007 | 10:32 PM
1982CorvetteDude's Avatar
1982CorvetteDude
It varies by area, I paid $400 to get a TH250 rebuilt a few years ago. I would check with the local parts store and see what it would cost for a rebuilt unit and do a swap out.......be a whole lot faster.
Old Sep 15, 2007 | 09:01 PM
markdtn's Avatar
markdtn
I haven't had one done in quite a while but I would have said $500 for a TH350 lockup assuming no hard parts are bad.
Old Sep 15, 2007 | 10:28 PM
SIXFOOTER's Avatar
SIXFOOTER
Thats probably about right. But a 350 is simple enough you can do it yourself. However, I think I would use the oportunity to upgrade to a 2004R
Old Sep 15, 2007 | 11:32 PM
sly vette's Avatar
sly vette
Auto or manual...Please fill out your profile!
Mark
And welcome to the maddness!!!
Old Sep 16, 2007 | 01:02 AM
7T1vette's Avatar
7T1vette
How much to rebuild a tranny...or how much to have it rebuilt? Rebuilding one yourself is relatively inexpensive...if you have the area, tools, equipment and know-how to do it. Even if you take your converter to a shop to have flushed out (assuming it doesn't need replacing), you could do it for around $200-300 in rebuild kit, gaskets, filter, and new fluid. If you have it rebuilt [correctly] it would be in the area of $750. You can buy a like-new tranny from suppliers for about $2000. If you can do-it-yourself, go that way; at least you will know what you found and what you did. Next choice would be to go to a reputable transmission rebuild place (call some car clubs for recommendations). Also, if you have it rebuilt, let them remove and install the tranny; that way the installation will be warranted also.
To transmission
