72LS1Vette Project making Progress
Old Oct 28, 2007 | 05:16 PM
72LS1Vette's Avatar
72LS1Vette
Another month of weekends gone this thing is finally starting to look like something that will be finished someday. Spent most of the time working on the engine, cleaning and detailing. Ordering brake lines this week so I can run the new fuel line parallel to the brake line on the driver's side.
Rick B.
Old Oct 28, 2007 | 11:34 PM
10gears's Avatar
10gears
Default 72 Ls1
Rick B.
Looking good is that corvette motor or camaro.
Old Oct 28, 2007 | 11:37 PM
78Vette-SA's Avatar
78Vette-SA
Looking great and coming right along. Gonna be sweet.
You do know the engine is not stock right? I could be wrong but it looks like heads (and underdrive pulley) have been installed. Note the ARP head studs (and of course the Meziere must have been installed for some reason like to keep cooling at max with the underdrive pulley if that's what I think it is, and the catch-can/oil separator, and external fuel pressure gauge line)! The heads have at least been off before as GM never installed the ARP's on an LS1. If you don't know the cam specs you may want to pop the rear cover and get the make/serial number off the cam and see if you can get the specs. Will help for tuning if in fact it has been changed. Of if you are good with a dial-indicator and degree wheel you can figure it out.
Also, you probably know you can loose the evap purge and fat PCV hoses to clean things up a bit. If you ever need a hand with anything, just shout.
Joe..
Old Oct 29, 2007 | 12:06 AM
78Vette-SA's Avatar
78Vette-SA
ps: Saw your earlier post on the shifter. For my 81 which was an auto, I had to offet the shifter about 1.5" at 45 degree angle. McLeod makes offset shifters. I decided to do my own and a buddy welded it up for me.
Old Oct 29, 2007 | 12:30 AM
72LS1Vette's Avatar
72LS1Vette
The motor is from a 2001 Camaro. The trans is from a differerent 2001 Camaro. The Corvette oil pan is different and the alternator, etc. are located in different positions on the Corvette. The F-body engines are an easier fit in the C3.
Rick B.
Old Oct 29, 2007 | 12:51 AM
72LS1Vette's Avatar
72LS1Vette
Joe..
Joe,
I knew that the engine had been worked on when I bought it - the guy I bought it from didn't build it but he claimed he did a 11.7 quarter mile with slicks so it may be pretty healthy. The rockers look stock but the heads may have been ported. Good tip about the cam. He didn't know what cam was in the motor and I didn't know how to figure that out. Hopefully there are some marks on the cam. The trans has to come back out anyway since I don't have a clutch yet. I didn't know that was an underdrive pulley either.
When I saw the ARP studs and saw how much the Meziere pump sells for I figured the guy wasn't totally BS-ing me. I'm hoping the motor runs good when I fire it up but so far everything I've seen looks OK. Valvetrain is very clean and plugs all look the same.
I would like to get rid of the evap purge (is that the black valve connected to the TB?). Can that just be removed and capped off?
I'm not sure what to do about the oil seperator. It's plumbed into the PCV line, and since I've never seen one on an engine before I'm not sure what the advantages are of having one. If it's useful I'll find a better way to mount it.
Rick B.
Old Oct 29, 2007 | 12:57 AM
72LS1Vette's Avatar
72LS1Vette
Nice job on the shifter. I looked into the McLeod shifters but I can't see spending $400 for a shifter. I'll most likely do domething similar to what you did. One more design project I have is a mount for the McLeod clutch master cylinder that came with the trans.
Rick B.
Old Oct 29, 2007 | 06:14 AM
78Vette-SA's Avatar
78Vette-SA
Joe,
Rick B.
Rick,
The evap purge can just be removed. You can program out any codes it might otherwise generate in the PCM. If you are using the factory harness you cap off the wiring. Most aftermaketer harnesses due not have provision for it.
The oil separate is not a bad thing to have. LS engines are known to pull oil through the PCV system and then back into the intake. Soem more than others. The separator keeps that oil from going back int he engine and fouling up plugs. You can shorten it a lot and there are mush nicer ones (and colored) that have a one bolt mount to the front of hte passenger head and go inline between the valve cover and behind the throttle body. When you are close to it I wouldbe happy to help you with plumbing and wiring. Phone call would be easier. Feel free to call me anytime after noon. (845-542-8930).
If the car is turnig 11.7 1/4 then it's pushing probably around 425-450hp which means is most like has had a cam and/or heads. My guess would be yes. Many manufacturers have their name and a serial number on the back side of a cam engraved in it. Lets say it's a comp cam, you could call them and give them the info and they should be able to provide you a cam card for it. If you do pull the rear cover off, mark is left to right so it is re-centers over the end of the crank. You can reuse the rear gasket but would be better to replace. Put two tabs of RTV in each bottom corren where it meets the oil pan and that's all you need.
As far as the clutch goes do you have a link or pic of the McLeod M/C? Is it a flat mount or offset mount like the Camaros. If offset, see the thread SuprJames has going on the clutch setup.
ps: The SRIII chassis I used also required the F-Body pan and I am using an 02 T56. Basically the same setups I just blinged it a bit. You'll enjoy the ride!
Old Oct 29, 2007 | 07:57 AM
RATT7's Avatar
RATT7
Looks really good !
Old Oct 29, 2007 | 03:14 PM
72LS1Vette's Avatar
72LS1Vette
Rick,
Joe,
Lots of good info here. I'll probably copy a lot of this stuff over to the sticky thread so that it will help others also. I definitely want to get rid of the purge valve. I need to neaten up the stock harness anyway so i can remove the plug and wires.
It looks like there is some sort of check valve in the original PCV system that the seperator is plumbed into? I think there was some oil leaking out of it and running down the head. The valve doesn't seem to fit very tightly in the PCV hose. Tell me more about re-routing the PCV hose. Do you retain the PCV valve and run a smaller diameter hose along the driver side and beneath the throttle body to the seperator? It sounds like if there is a sperator there isn't a need for that check valve if that's what it is. Thanks for the offer to help. I'll keep your number on file. I won't be getting the body back on until Spring and at that point I'll be mounting the ECU behind the dash and running the harness. I have a computer/ee background but having someone around who has been there/done that is very valuable.
I'm planning on using the LS7 clutch so I'll be removing the flywheel. Good time to pull that cover and check out the cam. The guy I bought the engine from said it had a non-stock cam but he didn't know what it was. I believe the ECU was re-programmed also but it would make tuning issues a lot easier if I know what cam is in there.
I don't have a pic of the clutch M/C but it came from the 2001 Camaro that the trans came from. I didn't know SuperJames had a thread going on clutches. I'll look it up.
Blinged it a bit? That's an understatement! That's one of the nicest looking LS engines I have seen.
One more question - where did you get that straight water pump fitting seen in the pic? My son ordered one from Summit that was supposed to be for a LS1 but when he brought it over on Saturday it didn't fit.
Thanks again.
Rick B.
Old Oct 29, 2007 | 07:33 PM
Scooter70's Avatar
Scooter70
Looking good Rick. It's really coming along.
You can get a straight water neck from CSR. The cool thing is that it uses an SBC thermostat so you can choose your temp. http://www.csr-performance.com/csr_cooling.html Part #911LS1.
Here's my modified Pro 5.0 shifter:
For the motor mount plate that I used, I had to go rearward with the shifter to fit through the stock console plate whereas Joe had to go forward.
Old Oct 29, 2007 | 08:44 PM
78Vette-SA's Avatar
78Vette-SA
Joe,
It would be great to break the sticky into Parts, Links and Howto's. Would be a lot of work for someone (and "borrow" some from LS1TECH.COM) but would be very helpful.
Yes, that's all you need. Some 3/8" with a couple elbows and a "T" and you are done. You could alternately just use valve cover breathers but that costs a few bucks to change.
If you have not already purchased the clutch, you may want to consider some cost effective alternatives. You won't have any problems with it, but there are options. If you bump the motor up further in HP or your are a spirited driver it may not be the optimum choice.
If it looks like this, mounting it took a little machine work as can be seen by the block below. I also had a reinforcement plate on the interior side but it was maybe a little overkill. You'll see more in SJ'f threads.
Scooter (who did his before man of us and did an incredible job) mentioned CSR's and I've seen their stuff, good stuff. Street & Performance also has some good stuff also on the expensive side though) at www.hotrodlane.cc. For the heater lines you can just get a 90degree -10 and -12 swivel (only one needs to swivel to install them but two would be better) from any speed shop that sells fittings such as "Earl's".
I think I did a bad job of inserting into the above. Hope you can read it.
Old Oct 29, 2007 | 09:32 PM
  #33
Road-Race Vette's Avatar
0Road-Race Vette
Former Vendor
You make us Boston guys proud!!!!!!! Awesome.
Old Oct 29, 2007 | 09:58 PM
  #34
72LS1Vette's Avatar
72LS1Vette
Thanks for the pointer to the water neck. It looks like they are available from Jegs as well as from CSR. I'm going to verify with Meziere that the neck bolt pattern is a stock LS1 size. I'll probably have to wait until the body is back on to see exactly where the shifter is going to end up. I really enjoy working on these problems. So much more interesting than my day job.
Rick B.
Old Oct 29, 2007 | 10:04 PM
  #35
72LS1Vette's Avatar
72LS1Vette
Do you like that custom wood rear suspension? It's made from recycled broken Red Sox bats.
Rick B.
Old Oct 29, 2007 | 10:43 PM
  #36
72LS1Vette's Avatar
72LS1Vette
No problem reading the post. You brought up a few more interesting points.
Maybe somone could get the mods to set up a LS1 Conversion sticky and sub-categories like you mentioned above. Then everyone could add info at will and no one would have to bear the burden of compiling all of the information.
I'm open to suggestions on clutches. Scoggin-Dickey has the LS7 clutch/pressure plate/flywheel for $400, which seemed like a good deal. If there is something else as good for less $ I'm all ears. I'm on a tight budget so if I can save some $ on parts somewhere it can go to other parts.
The clutch MC looks like it is going to be tricky/PITA to install properly. Is there an alternative that you know of that would work as well and be easier to adapt? I can always sell the McLeod MC and buy something else.
Rick B.
Old Oct 30, 2007 | 01:51 AM
  #37
78Vette-SA's Avatar
78Vette-SA
With regard to the Messiere:
It use the stock LS1 nexk, but the nexk only. It does not use the theremostat. You actually have to cut the tabs off of it that hold the thermostat in place or use an LS2 style housing whihc does not have the thermostat mounted in it. Email me your raddress and I'll send you an extra housing I have that should work.
Also with the mezziere:
A: Make sure you wire in a relay. They did not come with one but should be used. They draw quite a bit of current. Will save from blowing some other circuit later when it's hard to get at. Also, if you haven't, read this on the install. Although already mounted, it will help.
http://www.ls1howto.com/index.php?article=26
B: The thermostat for the Messiere is in the top nexk right below the throttle body. This is opposite of an LS1/2/6/7. PIck up a 160 thermostat if not already in there and make sure there is a tiny hole drilled in it to allow venting. It will make "burping" the engine cooling system a snap instead of a pain. Ths is also in the article but they make a 3/16" hole. I would just use a very small drill.
If you look in the top neck, you will probably already see that it is there. This neck unscrews on top. May need a monkey wrench or something to help it along.
As far as the clutch goes, even if you have to spend an extra $200 or so on a Centerforce or Ram setup (The Textralia would be the way to go but they are twice as expensive) I would go with the Centerforce or Ram).
The M/C install perhaps Scooter can describe what he did. I hae only used the Camaro style offset M/C but like in the post, had my brother do some machine work. SJ is looking at other approached also.
Joe..
To 72LS1Vette Project making Progress
Old Oct 30, 2007 | 12:26 PM
  #38
72LS1Vette's Avatar
72LS1Vette
Joe,
Thanks for the offer. I'll send you an email with my address.
I have a couple of relays that came along with the engine. I'm going to put an extra fuse/relay panel somewhere since I need a relay for the fuel pump as well as the water pump. I may rewire the headlights with a relay 'while I'm at it' also. There is a thermostat in the straight neck on the pump. I haven't taken the neck off yet to check it out but I'm curious to see what they put in there. Good point about the hole - I had read about that somewhere else but forgot about it.
I'll have to check those out. I like to boot it but I'm more of a 2nd and 3rd gear stomper. I have 2 sons in their 20's so I imagine that when I'm out of earshot there's going to be some tire spinning.
Joe..
I'll start looking around for info on clutch cylinders. Maybe there's a GTO or truck cylinder that would be an alternative to the F-body. The body of the car is sitting with the clutch rod hole right at face level. This winter will be a great time to work on the clutch cylinder mount.
Rick B.
Old Oct 30, 2007 | 03:28 PM
  #39
Scooter70's Avatar
Scooter70
Jeff, Buddy, and I used a flat metal plate that bolts behind the brake master cylinder and extends down to hold the clutch master. There's a drawing somewhere... probably on LS1Tech... in the Sticky.
-Matt
Old Oct 30, 2007 | 03:50 PM
  #40
72LS1Vette's Avatar
72LS1Vette
-Matt
Thanks. I'll try to find the drawing over there. I'll have to get the cylinder out of the body tonight and take some pics. I haven't looked at it for a month or so and I don't remember if it is angled exactly like the stock cylinder. Most likely it is but with the aftermarket you never know.
Rick B.
