a/c blower fan problems
Old Sep 18, 2007 | 05:07 PM
andylmusic76's Avatar
andylmusic76
Default a/c blower fan problems
so my mechanic fixed my a/c, and it works really well now. the only thing is i have to manually turn the fan off when i turn off the car. once it is turned off, it won't turn back on till the car's on again. when it shuts off, i hear a bunch of shorting sounds for a while, then it goes away. any ideas?!?
Old Sep 18, 2007 | 06:06 PM
Durango_Boy's Avatar
Durango_Boy
You say it only clicks when you turn it off and then it goes away? Could it be a leaf in the fan that makes the noise until the fan stops rotating?
Old Sep 18, 2007 | 06:09 PM
andylmusic76
it's definitely an electrical sound. but why would it stay running even when the ignition is off until i turn it off myself?
Old Sep 18, 2007 | 06:10 PM
Durango_Boy
I'm thinking a sticky relay. I don't quite understand the symptoms so maybe someone else has a better grasp but a relay sticking would provide power even when the trigger is cut off.
Old Sep 18, 2007 | 06:16 PM
7T1vette's Avatar
7T1vette
Sticky relay sounds like a good possibility. Either that, or the mechanic wired it all up wrong.
To a/c blower fan problems
