Need a new engine.
Old Sep 23, 2007 | 03:08 PM
SKONGEN's Avatar
SKONGEN
Default Need a new engine.
Hi everyone.
I have a -73 350/400
I need a new engine.I have tried "everything" but it still smokes ,left side.
All the spark plugs are tan/white .
Were can I bye the best/cheapest engine for my Corvette (Create) 350 HP
Regards
Stein Helgesen
Norway
Old Sep 23, 2007 | 05:14 PM
avner's Avatar
avner
Hi,
First check if the compression of the cylinders is OK.
If yes, check the Valve Stem Seal?
Avner
Old Sep 23, 2007 | 07:01 PM
ghoastrider1's Avatar
ghoastrider1
if you have a GM dealer anywhere near you, you can buy a fully warrentied engine crate engine.
Old Sep 23, 2007 | 08:37 PM
Roughrider's Avatar
Roughrider
GM Performance 350 HO crate engine...best bang for the buck. Not that you can't find something else cheaper (and less powerful), but hard to find new engine that does what the 350 HO does with a new warranty along with it.
Old Sep 24, 2007 | 07:24 AM
markdtn's Avatar
markdtn
Why not rebuild what you have? Probably cheaper overseas than trying to find a crate engine.
Old Sep 24, 2007 | 07:34 AM
Paul L's Avatar
Paul L
About $25.00 worth of valve stem seals can work wonders.
Old Sep 24, 2007 | 10:48 AM
SKONGEN's Avatar
SKONGEN
Have chevy alu heads (88-) .All new valve stem seals (umbrellas)
0.030 block,checked piston rings,(OK) new intake (edelbrock 2701) New carb (edelbrock 1406?) .CompCams 12-238-2.
Old Sep 24, 2007 | 11:06 AM
SKONGEN's Avatar
SKONGEN
It will cost more to rebuild than buy a long block (260HP) $5500. Mine is approx.320HP.
Here it will cost about $ 8-10000 fore a crate 350HP with flat tappet cam.
If I can get a "good deal" in USA it will cost me shipping + 25% tax of bill.
Old Sep 24, 2007 | 12:03 PM
Young69Owner's Avatar
Young69Owner
My 350/285 was $1600...
Old Sep 24, 2007 | 01:14 PM
Matt Gruber's Avatar
Matt Gruber
did u use a soft GM intake gasket?
Blue permatorque often wont seal
Old Sep 24, 2007 | 02:04 PM
SKONGEN's Avatar
SKONGEN
I used Edelbrock intake gasket.
Old Sep 25, 2007 | 12:05 AM
markdtn's Avatar
markdtn
A nice rebuild kit should be under $1000 here with the best of everything for a mild performance rebuild. Machine work can be done locally, in US around $1000 or less depending on head work required. Is it that much more there? If you don't have a rod hanging through the side of the block-which you don't-I can't see why that wouldn't be substantially less money?
Old Sep 25, 2007 | 09:59 AM
my83432's Avatar
my83432
What color is the smoke? Are you burning coolant or oil? Are you smoking all of the time or just on startup.
Old Sep 25, 2007 | 11:19 AM
SKONGEN's Avatar
SKONGEN
It`s smoking blue when it ´s getting warm.When hot it always smokes.
Never smokes when cold ,but after a few minutes.
You don't live in Norway.
One liter 95 gas cost $1.80-1.90
Old Sep 25, 2007 | 12:46 PM
markdtn's Avatar
markdtn
You said US price plus shipping plus 25%. That ought to be $1000+$200 shipping at the most+$300 tax. How much is machining there?
A whole engine say $3000 + $600 + $900 tax, that has to be more money.
Old Sep 25, 2007 | 12:57 PM
ghoastrider1
heres an idea...fly me and rebuild parts kit over and i will rebuild in a weeks time. I will,of course, buy the beer.
Old Sep 25, 2007 | 01:16 PM
GD70's Avatar
GD70
What ever you do, if it's #'s matching, keep the original engine, even if you put in a crate engine.
To Need a new engine.
Old Sep 25, 2007 | 01:52 PM
my83432's Avatar
my83432
I would guess that the smoke is white then. I don't know that you need a new engine as long as your oil pressure is still good. Did you do a compression test? It sounds more like a bad head gasket or a cracked head.
Old Sep 25, 2007 | 02:33 PM
rihwoods's Avatar
rihwoods
The cheapest GM crate motor (350) is made in Mexico....350....$1200.00
We call them "No HUEVOS"...
Old Sep 25, 2007 | 04:45 PM
SKONGEN's Avatar
SKONGEN
The smoke is always BLUE, the oil pressure is between 40 and 60.
The block is original but the heads are Chevy alu. intake and carb is Edelbrock.
I took a leak test today and that was fine.No leak into intake or headers.
I have only ran the car about 1500 miles after re-done the heads last winter.
