LT-1 identification
Old Oct 17, 2007 | 10:17 AM
  #41
Bullshark's Avatar
Bullshark
CI 5 & 8 Veteran
Early 70 LT-1's had a larger oil pan, and they all had unique alternator and starter part #'s. I don't have the part #'s handy but someone here may be able to chime in.
Bullshark
Old Oct 17, 2007 | 11:48 AM
  #42
mpett1's Avatar
mpett1
Originally Posted by gccch
This is why I started this thread... to list all of the unique features of the LT1. This is the first time I've heard of the U-joint straps. Are you talking about the rear axle u-joints or on the drive shaft or both? Any pictures available?
So far I know of these items to look for:
1) 6500 red-line tach (5500 with AC)
2) hood
3) 27" radiator, no overflow container
4) aluminum intake with Holley carb
5) 370HP shifer data plate, 11:1 compression
6) single fuel line
7) M21 or M22 trans
8) posi rear with 3.70 or higher gears
9) L in the VIN for a '72
10) Heavy duty U-joints
11) Block numbers for 370 ('70) or 330 ('71-'72) HP motor
Anything missing?
a 70 LT1 did not come with AC and could only get them in 4 speed.
Old Oct 17, 2007 | 11:50 AM
  #43
mpett1's Avatar
mpett1
Greg I am right around the corner from you. If you need someone to tag along with you to look at some potential cars let me know i will be more then happy to lend a hand.
Old Oct 17, 2007 | 12:23 PM
  #44
gccch's Avatar
gccch
That would be great! I've not located too many candidates nearby so far but will let you know as soon as I do.
Greg
Old Oct 17, 2007 | 01:33 PM
  #45
mpett1's Avatar
mpett1
Ok I will keep a lookout for you.
Old Oct 17, 2007 | 03:08 PM
  #46
wallifishrmn's Avatar
wallifishrmn
You forgot about the transistorized ignition. The only 350 to have that was the LT-1. This would be very erxpensive to duplicate. Just to get my TI back in working order will cost me about $1800 and I have all the parts except the coil and harness (TI distributor--check numbers, TI coil, TI harness, and TI amplifier). Look for the amplifier which is bolted to the drivers side front wheel well next to the radiator. The amount of meney it would cost to build an LT-1 it would be cheaper to buy one.
Buy from a reputable dealer that knows corvettes and will stand behind the car. Also talk to previous owners.
Old Oct 17, 2007 | 03:28 PM
  #47
Bullshark's Avatar
Bullshark
CI 5 & 8 Veteran
Good catch, but not all LT-1's had TI. My 72 w A/C does not.
Bullshark
Old Oct 17, 2007 | 03:35 PM
  #48
mpett1's Avatar
mpett1
Wrong info My 70 350/350 car has this. Ckeck here
http://www.100megsfree4.com/corvette/1970/vet70.htm
Old Oct 17, 2007 | 05:30 PM
  #49
wfo76's Avatar
wfo76
5600 with A/C as others have said (same tach from the LS5)
7) M21 or M22 trans
M20 with 3.55 was the way it would come if you didn't order anything different; 3.36 or 3.70 also avail with M20.
M21 was optional and came with 3.70, could also order the 3.55 or 4.11 with M21.
The M22 was included with ZR1 all three years but could be ordered on the LT1 without ZR1 in 71 only.
3.36, 3.55, 3.70, 4.11 and 4.56 all were available with the 4.56 reserved for the ZR1 in 70 and 71.
Bullshark
TI was dropped after 71.
Old Oct 17, 2007 | 06:35 PM
  #50
gccch's Avatar
gccch
Good stuff! Thanks, guys... this is what I was hoping for with the original post.
Greg
Old Oct 17, 2007 | 06:37 PM
  #51
Wilross3's Avatar
Wilross3
Great stuff! Just what I'm looking for too. Thanks for the original post Greg!
Bill
Old Oct 17, 2007 | 07:00 PM
  #52
spf72's Avatar
spf72
Reading this thread is making me think I should call the original owner of my 70. I have his name on the protectoplate and have another thread going on trying to firgure out what some of the numbers mean. Another forum member looked the name up in Yahoo and found the phone number. I wasn't going to call as it is a different first name but it sounds like this could be good info to go with the paper.
Old Oct 17, 2007 | 08:56 PM
  #53
gccch's Avatar
gccch
Steve,
I put that up for you... but maybe you didn't notice the street address is the same. 37 yrs. and still the same house. If I were in your shoes I would make that call every time.
Greg
Old Oct 19, 2007 | 10:11 AM
  #54
R1234's Avatar
R1234
Greg
Greg,
Here some more part number info to look for on a 72 LT-1 with A/C, iin case you run across one. These are from my car. So far the starter, coil and possibly the fuel pump have been changed out. I did find a BR270 coil at Carlyle this year.
Trim tag;
Build date - I27 - April 27, 1972
Paint code - 946 Elkhart Green
Interior Trim - 421 Saddle - Leather - Deluxe
Vehicle Identification Label - 1Z37L2S519882
Windshield pillar -1Z37L2S519882- April Corvette final monthly serial numbers - 519993
Tach- 5600 rpm redline
Engine casing # - 3970010 - Date B112 - February 11, 1972
Engine pad stamp # - 12S519882 V0422 - April 22, CKY -LT-1 1972
Driver’s side head - 39733487 X 02 2 guide plates visible.
Carburetor - 3999263 Primary - 7102 Secondary - 7101 Source - 6239-1 Date= 1B2 - 1971 Dec. 2nd week
Distributor Tag - 1112101 Date = 2D5 - April 5, 1972
Coil - 087 12V not original - found a original BR270 at Carlyle
Exhaust Manifolds - Driver= 3932461, Passenger= 3932461
Alternator - 61A 1100544 , Date= 2C7 - March 7, 1972
Starter - 1108368 Date= Jan. 25, 1971 not original. Still looking
Fuel Pump - ????- Still looking
Fuel line = 1, no return.
Master Cylinder - 5480346
Smog Pump - 7801149 Date= 04221S - Feb 11, 1972, shift=1, model= S
Diverter Valve - 29199, code -GL
Check Valves - left, right -5361992
Air Hoses - Left= 3932476 GM RC KV, right= 3947740 GM JA
Fan - Date= D72 - April 1972
Transmission - P2D20 A = M-20, vin #- 12S519882
Differential Code - AA W 103 E 1 = 3.55 ratio, Warren, April 12, Eaton, Shift-1 HD caps.
Old Oct 19, 2007 | 10:14 AM
  #55
R1234's Avatar
R1234
Well guys, it looks like it's official. I will be putting the 72 LT-1 fully loaded and documented with A/C on the blocks soon. Stay tuned while I figure out how best to approach this and how much I want to ask for it.
Later,
Bullshark
one on left
one on right
Good luck with the sale. I'll be watching this one closely.
Bryan
Bryan
Old Oct 23, 2007 | 08:48 PM
  #56
gccch's Avatar
gccch
Originally Posted by 68rdstr
Greg,
Trim tag;
Hey, 68: This is a nice guide for me to use. The one I'm checking out has B26 on the trim tag. I see this does not correspond to the same code for block casting number in yours above - yours is I with engine cast B. I assume B is for February for castings and September for final assembly?
Old Oct 24, 2007 | 06:20 AM
  #57
R1234's Avatar
R1234
The 1970 trim tag and block sequence begins in Jan 70. The trim build dates stop at Aug . The block dates continue on until Dec.:
Trim tag/block
a=Jan
b=Feb
c=March
d=April
e=May
f=June
g=July
h=August
block only
i=Sept
j=Oct
k=Nov
l=Dec
The 72 trim tags begin in Aug 71 and run through Aug 72. The blocks follow the same Jan thru Dec pattern which is A - L
a=aug 71
b=sept 71
c=oct 71
d=nov 71
e=dec 71
f=jan 72
g=feb 72
h=mar 72
i=apr 72
j=may 72
k=jun 72
l=jul 72
m=aug 72
Bryan
To LT-1 identification
Old Oct 24, 2007 | 12:09 PM
  #58
wallifishrmn
Where did you get the number for the coil? My book says it should be #1115270. Thanks
Old Oct 24, 2007 | 02:16 PM
  #59
GD70's Avatar
GD70
Here's a couple pics of my friends #'s matching 70. His is early with the larger oil pan so no room for power steering.
Old Oct 24, 2007 | 02:25 PM
  #60
Bullshark's Avatar
Bullshark
CI 5 & 8 Veteran
Glenn, Quick question on your friends 70 LT-1. I noticed it has a water pump on it with the pluged bypass port. I that original on these early 70 LT-1's
Bullshark
