1978 and 1982 differences???
Old Sep 27, 2007 | 11:30 PM
vetteguy112233's Avatar
vetteguy112233
Default 1978 and 1982 differences???
My Alldata program only goes back to 1982, I know 78-82 are basically the same. I've got a 78, what are the main differences from a 1978 to 1982?
Should all wiring/vacuum diagrams be the same? I don't care about the motor and trans, because I don't have the originals (in the car). Any MAJOR differences?
Old Sep 28, 2007 | 12:43 AM
RockyL32's Avatar
RockyL32
From: If your not the lead dog the view never changes Boise, Id
I believe the nose and rear are different and in 82 they put in a crossfire injection and a little computor to run it, some 82 (the SE) the rear window was a hatch to ease access to the rear compartment
Old Sep 28, 2007 | 04:48 AM
hunt4cleanair's Avatar
hunt4cleanair
Due to the electronics, emission control devices disappear and that includes the hoses. It still has the vapor emission control devices and hoses as well as exhaust emission controls (cat converter).
Must weight saving efforts were made that can be seen with rear crossmember (alloy), rear monoleaf spring (non FE7), differential carrier.
Heavy looking nose with spoiler rearend.
More convenience options as base equipment like windows door locks, courtesy lights.
Old Sep 28, 2007 | 08:14 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
78 Pace Cars and all 79-82 models got improved seats. California '80s had the Rochester E4ME computer-controlled carburetor, as did all '81s. '82 got the Cross-Fire injection system. '80-'82 had redesigned front and rear bumper covers. No manual transmissions were available in '82. The '82 CE had an opening rear hatch. '81s with the digital radio and all '82s had an oil temperature gauge instead of the clock.
Old Sep 28, 2007 | 08:23 AM
pbcanney's Avatar
pbcanney
80-82's got lighter duty driveline parts from the front universal back as well. Not that they are made out of glass or anything, but something to consider if you are a weekend warrior, or want to show off at every stop light.
Old Sep 28, 2007 | 09:12 AM
Red 69's Avatar
Red 69
Starting in 1980 the differential went from the 'iron' case to the Dana 36 or 44 if an L-82. The Dana 44 is definately the stronger unit, but drag racers prefer the old 'iron' unit. The old iron differential and Dana units do not interchange without extensive modifications. If you have an 80 up car you are racing, the Dana 44 would be the preferred unit.
In 82 the rear hatch glass was only offered in the CE model. The 82 model came with the 700R4 OD transmission. The other differences are already mentioned.
Old Sep 28, 2007 | 01:22 PM
RockyL32's Avatar
RockyL32
The information on this forum astounds me
Old Sep 28, 2007 | 02:19 PM
79L82owner's Avatar
79L82owner
Thats why dummies like me hang out here.
Old Sep 28, 2007 | 02:22 PM
Mark_Milner's Avatar
Mark_Milner
No, not the same but close on most. The reason is the '82 used the Cross Fire injection with two TBI on a crossram manifold. As such, there were parts to run this and wiring differences.
The rest of the car is pretty much the same.
Old Sep 28, 2007 | 02:49 PM
rihwoods's Avatar
rihwoods
Another big difference is the 80-82 vettes have 45% improved air flow thru radiator due to front bumper/air dam design.....
Rich
Old Sep 28, 2007 | 02:53 PM
markdtn's Avatar
markdtn
Wiring other than the engine will be similar, but the fuse box bulkhead arrangement will not be the same. As mentioned, the rear axle and suspension are different. Can't you get the Alldata info for like $20 a car?
Old Sep 28, 2007 | 05:43 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Makes a decent explanation of the differences between model years. So does The Corvette Black Book.
Old Sep 28, 2007 | 10:39 PM
vetteguy112233
My car is the L82, does this mean it's a Dana 44? How can I tell what is in it, just in case it's not the original housing. I've got 3.70 gears if that helps with anything.
Old Sep 28, 2007 | 10:50 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
No, the aluminum D44 was introduced in 1980.
Old Sep 28, 2007 | 10:53 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I'm pretty sure all 80-82 models had the aluminum D44. The D36 wasn't brought into the Corvette lineup until the C4 introduction.
Old Sep 29, 2007 | 01:33 AM
Glensgages's Avatar
Glensgages
I believe this to be true also, but Red 69 is correct that even the 'big' Dana-44 wasn't built to win the 'Stop-Light Nationals' drag-races.....
Old Sep 29, 2007 | 05:39 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
The aluminum D44, unless it's set up just right, is known for not holding up. The earlier cast iron differential can be installed on the aluminum batwing, but I don't know the details. I think Van Steel might have been posting about it a few weeks back.
To 1978 and 1982 differences???
Old Sep 29, 2007 | 07:47 AM
79L48's Avatar
79L48
I shouldn't post if I am not SURE of the answer, but I believe the potential for different vacuum routing exists because the vacuum canister is different on the 80-82 than it is on 78-79.
Old Sep 29, 2007 | 11:33 AM
Red 69's Avatar
Red 69
You are correct, thanks for clearing up my error.
Old Oct 7, 2007 | 02:48 PM
vetdog's Avatar
vetdog
2nd Gear
Hi Batman, are you sure about the oil temp gauge ? my 82 has a clock,
It's not a CE. Just curious, no offence intended.
