I have a 78 with a stock L48. I've put about 200 miles on it in the last year. The engine has 81,000 miles on it. It could use new valve seals (winter project) but otherwise it runs perfectly. My question is, how often should I change the oil in a car that's not being driven much? I do start it and go round the block at least once a month, even in winter. What oil/weight should be used?
Also, what winterizing routine is recommended (Illinois winter)? Last year I filled it up with gas and disconnected the battery, and usually started it every couple weeks. It got to be in heated storage from January-April, but I don't think I can do that this year. It'll have to be in the detached garage this year, and it does get below freezing out there.
I would change the oil and filter every 6 months for the amount of driving that your doing and use any good quality 10w30 oil. For winterizing I would check the quality of your anti-freeze and make sure it is good down to -30 degrees, Drain your fuel tank or use Stabil in it. I would keep a battery tender on it or run it once a month if you can but make sure you get it up to operating temp and run the heater as well. You want to run it long enough to make sure that you get all the condensation out of the motor and exhaust system to prevent any rust or corrosion issues.
From: Downtown Annapolis, MD. The Future is where we all have to live. Let's not screw it up.
Originally Posted by supervette77
I would change the oil and filter every 6 months...
No matter how few miles you put on the car. I use Mobil1 10W30, and NAPA filters in my '71 and '88 and have never had an issue of any kind. Great stuff.
For older engines that aren't driven very much, synthetic oil is the best "all around" choice. Synthetics don't "oxidize" like organic oils, which means sitting around doesn't create a problem. It has MUCH better wear characteristics, so engine reliability is higher. But you might have a few more drips, seeps and weeps. Synthetic oil doesn't cause leaks....but it will flow through smaller openings. So, if your seals are marginal, it might drip a bit. You won't have to change it but once a year (or two, if you change filters on a shorter cycle).
