'69 side pipe question...
Old Sep 30, 2007 | 12:02 AM
chevyf16's Avatar
chevyf16
Cruising
Default '69 side pipe question...
Newbie here...just looked at a 69 today with "factory installed side pipes" but the tail exhaust cutouts could be seen in the back (from the inside). Is that right, or were they added afterwards??
Old Sep 30, 2007 | 08:25 AM
427SIXPACK's Avatar
427SIXPACK
2025 C3 ('68-'73) of the Year Finalist - Unmodified
2024 C3 of the Year Finalist - Unmodified
If you can see cut outs then the car didnt originally come with "PIPES FROM THE FACTORY" Factory "PIPE" cars had a different rear valence !!!
Old Sep 30, 2007 | 05:29 PM
Marks69BB's Avatar
Marks69BB
The seams where the rear valance meet the rear quarters will be straight instead of 'comma shaped' which means it has a replacement rear valance that fills the original rear exhaust cutouts.
Old Sep 30, 2007 | 09:36 PM
c69vete's Avatar
c69vete
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
Valance panels can be purchaced with 1/2 of the cutout for rear exhaust, with an "ear" on each side to fill the existing exhaust opening or with a straight vertical seam for a factory type look. A true factory side pipe optioned car, (69 only) had different rear fenders that had a straight, vertical line where it meets the valance. If the the fiberglass work you saw was on the fender side of the valance joint, then it was not a "factory" sidepipe car. Swaping the fenders is a lot of work to go thru to get the factory look.
Old Sep 30, 2007 | 10:20 PM
Corvette Engineering's Avatar
0Corvette Engineering
Former Vendor
You say the cutouts can be seen from the inside.
But not from the outside? If so it's probably a factory sidepipe car. they all came that way and the rear exhaust cars had them cut out. and a trim ring installed.
I would look at the rear filler panel. Make sure it's press molded etc.
someone could have put in a new correct filler panel.
Old Oct 1, 2007 | 07:20 PM
Alan 71's Avatar
Alan 71
I believe that sidepipe cars had specific rear fenders and rear valance panel. This is one thing GM did 'right' on these cars and didn't look for an easy way out.
Regards,
Alan
Old Oct 1, 2007 | 10:50 PM
chevyf16's Avatar
chevyf16
Cruising
Thanks!
To '69 side pipe question...
