Temp
Old Sep 30, 2007 | 04:24 PM
Lilfur's Avatar
Lilfur
Default Temp
On a 1968 Big Block 427 , what is the normal engine temp? Is 205 to 210 O.K. after have been idling for a while??
Old Sep 30, 2007 | 06:02 PM
chris75stingray's Avatar
chris75stingray
sounds good. does it get hotter in traffic?
Old Sep 30, 2007 | 07:00 PM
7T1vette's Avatar
7T1vette
The answer to your question is 180 degrees...if the cooling system is working properly. Engines & cooling systems were originally designed to operate at 180, and the '68s had 180 deg. stats in them. If yours has a 190/195 degree stat, you should change it out with a 180 hi-flow stat. If it already has one, your cooling system might need a good flush or cleaning...or have some other component problem.
Old Sep 30, 2007 | 09:59 PM
coinwasher's Avatar
coinwasher
Here we go again, anything over 200 is "pushing the envelope" 190-195 gives you a little wiggle room. The airflow on these cars never was great but with the new dewitts radiator and a good fan and pump setup you should be able to stay under the 200 mark even with cast iron heads. I have a 69 with a 427 stroked and punched to 469 cubic inches. Never goes above 195 even on 100 degree days.
Old Sep 30, 2007 | 10:58 PM
xCCTer's Avatar
xCCTer
CF JASOC Member
From: Downtown Annapolis, MD. The Future is where we all have to live. Let's not screw it up.
That's perfectly fine. The fans don't even kick-on in C4/5 Corvettes until 228* unless someone has installed something aftermarket, and then they turn off at 215* and so on.
Old Oct 1, 2007 | 12:08 AM
chris75stingray
the original temp guage doesn't hit red untill about 240* . so G.M must have thought if it stays under 240* then don't worry about it. i however don't want my engine running that hot . if it gets up to about 220 (which it will once in a while since i have a coolant leak) then i start to get concerned. if you have a stock setup it sounds fine, of course you can upgrade radiators and fans if you feel it is necesary
Old Oct 1, 2007 | 01:22 AM
427SIXPACK's Avatar
427SIXPACK
2025 C3 ('68-'73) of the Year Finalist - Unmodified
2024 C3 of the Year Finalist - Unmodified
big block 3x2 here went from a 5 blade non a/c car fan to a 7 blade ( still an original GM fan ) thats for an a/c car & usually doesnt go over 180 - except for extensive idling in the summer heat in traffic it may go to 190 but i have never, ever seen it go higher then that.
Old Oct 1, 2007 | 09:40 PM
7T1vette's Avatar
7T1vette
Later model vehicles are designed to run at 195 or higher. The 1960's and early 70's cars were designed for 180 degrees and had 180 stats in them. Can they run hotter? Sure... Should they? I guess that's up to the owner.
To Temp
