Wheel wells paint? or undercoat?
Old Oct 1, 2007 | 07:08 PM
Chandler's Avatar
Chandler
Default Wheel wells paint? or undercoat?
I cleaned off the old undercoat and fixed some fiberglass and seams, but now what? paint the wheel wels black? put new undercoat on the wheel wells?
other ideas?
thanks
Chandler
Old Oct 1, 2007 | 08:03 PM
SLVRSHRK's Avatar
SLVRSHRK
I just went through this myself in the front. After all of the effort that I put into removing the old undercoating, there was no way I was going to put it back on.
For mine, I stripped the undercoat, cleaned the areas with mineral spirits, and then cleaned them again with acetone. AFter they were clean, I primed them with a primer I got a Home Depot called Grippers. It's essentially a KILZ competit and is designed to cover just about anything that normal paint will not stick to. I figured left-over undercoat residue might be similar to crayola crayones on interior walls. I applied the paint using a 1 inch brush for the joints ad seams and then finished the large areas using a 2 inch wide foam roller (for house trim).
Final topcoat was a coat of Rustoleum Satin Black applied with the brush and roller, finish is outstanding (if I don't say so myself) and is thick enough to withstand a rock chip or two.
Good Luck.
Old Oct 1, 2007 | 08:44 PM
chris75stingray's Avatar
chris75stingray
i painted mine black. some people like to use undercoat on the back side of the fenders and 1/4 panels so if rocks hit it , they won't cause any cracks to the surface paint.
Old Oct 1, 2007 | 09:26 PM
hwcoop's Avatar
hwcoop
I cleaned my old undercoat off with a heatgun and I'm going to use black rubberized rockgard to recoat.
Old Oct 1, 2007 | 09:32 PM
bj1k's Avatar
bj1k
I'm painting the wheel wells semi flat black but undercoating the top part which is the fender so when rocks are picked up by the tires, it don't cause those little stars in the surface paint on the fenders. I don't know why people undercoated the inner fenders since they are not metal.
Old Oct 1, 2007 | 09:37 PM
rosslato's Avatar
rosslato
i brushed on por-15, it dries rockhard to repell rocks etc then i topcoated w/krylon semi black. it wipes off easy.
Old Oct 1, 2007 | 09:45 PM
7T1vette's Avatar
7T1vette
Clean them with the pressure sprayer (soap, then flush) at a coin-op car wash. Remove wheel, mask area and spray with Krylon semi-flat black paint [spray can]. It'll take about 1 can per wheelwell. Done deal!
Old Oct 1, 2007 | 10:02 PM
Red 69's Avatar
Red 69
I cleaned all four of my wheel wells down to bare fiberglass and molded them. All the bonding seams and nooks and crannies were filled with bondo and smoothed for easier cleaning. When it was sanded smooth I gave it two coats of PPG epoxy primer. The frame was painted black with POR gloss black. I broke my camera before I could take a picture of the front wells.[IMG][/IMG] The whole underside was done with the body on the car. Not many see it, but I know it is there.
Old Oct 2, 2007 | 04:33 AM
hunt4cleanair's Avatar
hunt4cleanair
Depends on the year, but I've used this rubberized undercoating that provides a nice flat, textured undercoat looking finish. The factory did a modest undercoat in wheel wells and finished with blackout...nothing fancy though.
Old Oct 2, 2007 | 07:36 AM
lvrpool32's Avatar
lvrpool32
I used tintable truck bedliner. I tinted mine yellow (good way to see leaks and stuff. You have to put somethng thick (bedliner, thick undercoating, I have even seen people glue 1/8th rubber)on the underside of the top of the fenders otherwise rocks/stones will crack the fiberglass (especially so on older cars where the glass becomes dry and brittle.)
Old Oct 2, 2007 | 09:00 AM
eastltd's Avatar
eastltd
Very Nice!! Looks much better then the ratle can finish.
Old Oct 2, 2007 | 02:47 PM
Chandler's Avatar
Chandler
Thanks for all the great tips! Red69 incredable finish ! Rosslato that front clip coming off is so cool, I hardly even looked at the wheel well part of the picture.
Old Oct 2, 2007 | 04:17 PM
Red 69's Avatar
Red 69
I agree, I always liked his car! If I can find the deal I after on a C-3, I'll be asking for tips on making a clam shell front.
To Wheel wells paint? or undercoat?
