Thought I'd share a few shots of the car. I've most of the body work complete and have three coats of hi build primer on her. (Top and Bottom) Hope you like it.
GREAT job man, you did a phenomenal job from the looks of it. Primer is always my favorite stage too because it's easy to go back over small mistakes. Once you shoot paint or even clear the margin of error goes bye bye.
What color will she be?
Thanks DB. It's coming together. I blocked out a quater panel this afternoon with 320 wet and it's looking real nice. The lines just pop! We're doing everything we can make sure we have no errors, time will tell.
Final colour is going to be Metallic Yellow with the under body painted slate gray to mimic the raw look of the fibreglass.
Metallic Yellow is a one year only factory colour, so I feel obliged to keep it.
From: Ville de la Baie Quebec. A winner is just a loser who tried again.
Nice work, the lines look good !! I just got mine back from the paint shop on saturday,, metalic silver. I know the feeling your going through. I can tell you it feels great when you see the results and final proof that the work was well done. Did you powder spray a guide coat on the primer?, It sure helps find those problem spots you'd never guess.
The old guy working with me was insulted when I suggested a guide coat. I guess I'll have to trust him.
I took twelve cases of empties back last week. You sure you can afford it?
4 carry the 3 , hhmmmm, I might have to sell the wife, but if I charge by the pound, i should actually come up with a profit...and if you tell her I said this I'll deny everyword of it to the grave, which I'll probably be headed for in a week.
You should be ashamed of yourself for saying that. I think you should be banished to the garage for a while
You did a GREAT job! You should be proud.
Keep in mine when you bond the headlamp bar to the surround, sand the primer off. It needs to be bonded directly to the fiberglass not the primer, or it will separate eventually.
Can't wait to see the finished paint.
Glenn
what did you do for cleaning up/smoothing out panel joints underneath?
Mine are sloppy looking with gaps that can trap dirt etc, just wondering what would be a good product to smooth things out?
(I'm thinking just more panel adhesive )
