1978 C3 Without headlight dimmer switch
Old Oct 9, 2007 | 10:50 PM
joegameY2J's Avatar
joegameY2J
Cruising
Default 1978 C3 Without headlight dimmer switch
I just purchased a 1978 C3 Corvette to start restoring. After a fun day of driving I couldn't find a switch to turn my headlights on Bright or to dim them. I thought the switch would be on the floor like the one you push with your foot. I looked down there under the carpet and I didnt find any loose wires or plug. Is the switch somewhere else or where can I find the wires to put one in?
Old Oct 9, 2007 | 10:59 PM
papawana's Avatar
papawana
it is part of the turn signal lever
Old Oct 9, 2007 | 11:00 PM
rihwoods's Avatar
rihwoods
I have a 78...it is on your steering column integrated with your turn signal lever...just pull it straight back for high or low beam...
My 69 is on the floor..
Rich
Old Oct 10, 2007 | 07:19 AM
tjhuyser's Avatar
tjhuyser
I wonder if he's feeling silly yet?
Old Oct 10, 2007 | 09:29 AM
Durango_Boy's Avatar
Durango_Boy
Maybe not. In my red '77, the switch did not function, and I gave up thinking it was a dimmer too. Turned out the switch failed and once replaced it worked great.
If his switch does not work, as most people know to pull that lever, it's easy to assume its not the dimmer.
Old Oct 10, 2007 | 11:47 AM
joegameY2J's Avatar
joegameY2J
Cruising
Thanks Durango. I tried the turn signal but it was real weak and didnt work so i thought it would be on the floor. Thanks for the help though. How did you replace the switch?
Old Oct 10, 2007 | 12:44 PM
rihwoods's Avatar
rihwoods
Do you hear your flasher ???
To 1978 C3 Without headlight dimmer switch
