Corvette consistent problems or defects
TIA WB
Could use a cool title for the article as well!
Bullshark
!) On earlier C3 models with a vacuum reservoir tank, they can develop fatigue cracks from years of flexing.....leading to abnormal windshield wiper door operation and vacuum leak related problems.
2) Those vacuum relays that control headlight and wiper door operation have a dog bone lip seal in them that always goes bad....just a matter of time.
I will pontificate on additional areas.....
Bullshark
The lower windshield frames get cancered out due to the way the thing is put together. The fiberglass bonding piece that the fenders bond to are not sealed to the frame. They are simply riveted to the WS frame corner.
This is the result
Here are the riveted areas, the red line indicates a leak candidate
The fiberglass piece should have been sealed with Urethane caulk to the metal piece of the WS frame corner. With just the rivets, it traps and holds water allowing the corner to rust thru. The water then runs down inside the door pillar and on top of the #2 mounts and this is what you get
The repair requires the cutting out and fabbing new pockets for the #2 mounts, store bought pieces are available. The WS frame repair required fabbing new parts because there were no store bought parts available, but there may be now
The floor I brush wheeled, chemical treated and then treated with POR15 and fiberglass matt
Bullshark
This is the result
Now that's one rusted out frame area!
Buying C3 Corvettes" - other chapters on - Problems*Solutions*PM.
You have two audiences - tech and non-tech so KISS principal should
be used. Here's just a few areas to be addressed--- Battery Cranking
Amps vs Cold Cranking Amps - Windshield window tray solutions -
installing brakes - and many more. Good luck on your project. It's
needed. Peter PS: possibly a vendor could support your project.
I think this is a great project...
(specially if you'll let me write and sign the chapter about the weight iussue...
1) Oil in the engine?
2) Oil out of the engine? (Always check running oil pressure)
3) Transmission rear seal?
4) Gas leak?
Electronics
1) What actually works?
2) Gage lights?
3) Instrument warning lamps?
4) DC Outlet?
Fiberoptics?
- Do the rear ones work?
Control Arm Bushings
-How do they look in the front?
Does the horn work?
-Can it be fixed by grounding it?
Are the tires road worthy or have they been sitting for several years?
Sorry for the long post, but these are just some of the issues I've already had.
4) Gas leak?
Electronics
2) Gage lights?
4) DC Outlet?
Fiberoptics?
Does the horn work?
Some more you guys may have run across unique to our vettes.
Gas tank sock filter breaking up and clogging the fuel pick-up / filter.
Maintenance free Emergency brake design!
Early C3 external door handle spring
High speed heater blower motor relay failure.
distributor mechanical tach gears
mechnical clock points wear
upper windshield post rust out causing leaks.
electronic tach boards burn out.
speedometer fiber gear wear
clutch fan failure
hood release lever cable
broken door hinge spring
I think I have dealt with all of these one time or another.
Bullshark
And, I almost forgot one of my favorites......now listen to this panic.......carburetors.....
but I guess that's not vette unique.
