Quick early C3 conv't hardtop question
Old Oct 24, 2007 | 04:40 PM
randyward's Avatar
randyward
Default Quick early C3 conv't hardtop question
Who can explain to me the hardtop bolt down mounting position? I believe that this is on the convert lid. If a car was ordered with the hardtop, did Chev install the bolts/nuts, but if no top was ordered, the lid was just left untouched?
Rand
Old Oct 24, 2007 | 05:47 PM
LYLE's Avatar
LYLE
Their was a center hole in the lid that covers the soft top and on each side of the lid their was threaded hole on the inside front corner on cars with a factory hardtop installed at the factory. If only a soft top was ordered the three holes were not in the lid. With the convertible top up the center hole is on the inside of the car.
Old Oct 24, 2007 | 06:29 PM
SteveG75's Avatar
SteveG75
Mine was an original hardtop car. Here is a pic that shows two of the three holes. You can see the center hole and one of the threaded holes (just in front of the passenger seat).
Old Oct 24, 2007 | 07:17 PM
randyward's Avatar
randyward
Great info- To be clear, if both the hard and soft top came from the factory, I would expect to see both the threaded holes on the front inside of the lid AND the one in the center? Did the center one have any function, or was it just for alignment?
Rand
Old Oct 24, 2007 | 07:27 PM
68raggtop's Avatar
68raggtop
I don't know what year the center bolt began, but they were not on 68's as far as I know. The 2 side bolts, 2 rear studs and 3 front locks are how it is held on.
Old Oct 24, 2007 | 09:01 PM
randyward's Avatar
randyward
Thanks!
Old Oct 24, 2007 | 10:35 PM
LYLE's Avatar
LYLE
I think their was a threaded stud in the hardtop that went through the center hole and a washer and nut on the bottom. I took the stud out and just used the other two holes on the side. The hardtop also used the holes where the softtop pins went to bolt down the hardtop with studs so i left the center bolt out.
Old Oct 25, 2007 | 12:23 PM
Roughrider's Avatar
Roughrider
The center hole wasn't installed until the late '69 model year or maybe the start of the '70 model year. My early '69 doesn't have the center hole. If you have an earlier model and a later removeable hardtop, you have to remove the center bolt.
Old Oct 25, 2007 | 01:16 PM
vettehed's Avatar
vettehed
You really dont need any of the extra factory holes to use a hardtop. The hardtop uses the same holes as the soft top to hold the back, and of course the same clamp arrangement that the soft top uses in the front. Unless you are just wanting to duplicate factory correctness, you dont need any of the extra holes. If you are concerned about the rear letting go for some reason, use studs with nuts as someone else suggested instead of the prong-style pins that the soft top uses. I have put these on without securing the back at all...it is so heavy, and with the 3 clamps in the front it wont go anywhere. Everyone thinks that they want a hardtop, but it usually comes off the car the day its bought, placed in the corner of the garage in the way of everything, and then goes back on the car the day it is sold. Do you other guys regularly use the hard top?
Old Oct 25, 2007 | 01:19 PM
vettehed's Avatar
vettehed
Meant to say that I read that the center hole was added later, as someone else stated, because of customer complaints that it did not seal good in the center of the decklid and leaked. The softtop rear bow is aluminum and can be easily bent to conform to the shape of the decklid to improve sealing, but the hardtop of course cant be bent to improve the seal.
Old Oct 25, 2007 | 09:13 PM
randyward's Avatar
randyward
Again, thanks to all for the information!
Rand
Old Oct 25, 2007 | 09:41 PM
Matt O's Avatar
Matt O
Rand
My 69 Vert with the factory hard top is the same as SteveG75 with the exception I don't have the center pin. Don't know when that started.
Old Oct 25, 2007 | 10:03 PM
avalonjohn's Avatar
avalonjohn
CF Community Team
Veteran: Marine Corps
St. Jude Donor '25
It must use the 2 side bolts in 68, and a center bolt in late 69. Trust me from experience, if you try to mount the hardtop the same way you mount the softtop, w/o using at least the 2 side bolts, it will fly off......cost me a small fortune to fix it.
Old Oct 26, 2007 | 07:58 AM
69L46vert's Avatar
69L46vert
I have an early 69 (late sept. 68) with no centerhole in the decklid and no provision for a centerbolt in the hardtop. Rick
Old Oct 26, 2007 | 02:03 PM
Roughrider's Avatar
Roughrider
The only reason I have a removeable hardtop is because the original documentation with my numbers matching '69 427/435 says it came with one, which became seperated from the car sometime in the past.
I found a really nice hardtop for my car that only needs to be painted a matching color. Even then, I doubt it I'll ever put it on the car.
To Quick early C3 conv't hardtop question
