engine differences
Old Oct 24, 2007 | 09:33 PM
jmp's Avatar
jmp
Default engine differences
My 71 cpe. has a 72 350/200. Is it actually the same motor and rating as a 71 350/270? Maybe thats when they changed how they rated HP? Also, is that a two bolt main block? Thank you.
Old Oct 24, 2007 | 10:31 PM
Road-Race Vette's Avatar
0Road-Race Vette
Former Vendor
what makes you think it is the 200hp motor? the numbers on it?
Old Oct 24, 2007 | 10:48 PM
BSiegPaint's Avatar
BSiegPaint
St. Jude Donor '06-'07
To add a bit, I have a '71 350/270 and it is a 2-bolt main block. What else can you tell us about yours?
1972 was the first year of lowered (gross to net) HP numbers.
Old Oct 25, 2007 | 12:01 AM
jmp's Avatar
jmp
I checked the letter code on the block, I forget what they were, but I looked it up in an old motors manual, and it said a 72, 200HP. Now, if thats correct that 72 was the yr. they changsd the ratings, I'm wondering if its actually the same 270 hp eng. from 71. ALLSO, I forgot to ask this in the original post, but it has those skinnier spark plugs. They didn't come uot till aroind 1980, right? Its got an edlebrock 600cfm perf carb, and an edlebrock perf. manifold also, don't know if cam was changed.
Old Oct 25, 2007 | 12:06 AM
0Road-Race Vette
Former Vendor
that being said,do the numbers on the front stamp pad in front of the pass side cyl head match your vin?
Old Oct 25, 2007 | 12:14 AM
jmp's Avatar
jmp
Where the heck is the vin, I looked through the windsheild where they usually are, and the drjam and didn't see it.
Old Oct 25, 2007 | 02:35 AM
Bruthish's Avatar
Bruthish
St. Jude Donor '03-'04-'06-'08-'09
SHould be on the pillar post , drivers side. Look upthe post from the outside and you should see a part of the trim cut away.
Old Oct 25, 2007 | 01:32 PM
vettehed's Avatar
vettehed
A 2-bolt main block refers to the number of bolts that secure the main (crank) caps to the block. There is a bolt on each side of the cap. A 4-bolt main block has 2 bolts on each side of the cap to secure it. In high-output engines, there is a risk of crank bearings "spinning" between the crank and cap surface, so the extra bolt adds strength. A 2-bolt can be converted to a 4-bolt by buying 4-bolt main caps and drilling/tapping 2 more bolt holes in the block.
Old Oct 25, 2007 | 01:34 PM
vettehed's Avatar
vettehed
Whoops! Just reread your post...you were not asking what a 2-bolt was, but if yours WAS a 2-bolt. I'm think that by this time in Corvette production, there were no 4-bolt blocks? Anyone?
Old Oct 25, 2007 | 05:11 PM
jmp's Avatar
jmp
Yes, I know about 2 and 4 bolt blocks, though I never new you could just add the extra hole to make it a 4 bolt, never really looked into it, I just assumed there wouldn't be enuogh meat on the journals for another bolt. How about those heads with the skinny plugs, you think thewre newer heads?
Old Oct 25, 2007 | 07:41 PM
mstanton's Avatar
mstanton
Chevrolet rated the 71 base engine at 270hp gross and 210hp net. 72 was the year that rating changed from gross to net, but there was actual hp loss in all engines, although very small.
Old Oct 25, 2007 | 07:45 PM
jmp's Avatar
jmp
Well that makes me feel a little better. Since I have the carb and manifold, maybe I should get a good cam and headers.
Old Oct 25, 2007 | 08:08 PM
BKbroiler's Avatar
BKbroiler
Chevrolet changed to the small diameter plugs in 70 or 71.
Old Oct 26, 2007 | 01:19 PM
GD70's Avatar
GD70
Would have to be after 70. My owners manual specs R43 R44's which are the larger plugs. They wouldn't fit my heads. My engine is not the original and uses the smaller "peanut" size plugs.
Glenn
Old Oct 26, 2007 | 03:57 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
4-bolt blocks were used long after 71. All L-82s should have 4-bolt mains, for instance.
Old Oct 26, 2007 | 05:21 PM
tjhuyser's Avatar
tjhuyser
ditto...if the casting is the same>>.WOO HOO!!! I got 3 4 bolt blocks that aren't done yet!!
To engine differences
