Engine Code Help
Old Oct 31, 2007 | 01:36 PM
Muchie69's Avatar
Muchie69
Default Engine Code Help
Hello Everyone,
New member here. First of all I want to thank you for this forum and the many questions and answers offered by other members. I have found it very helpful and informative. My question concerns the serial #106 2LM 199723653 stamped on my 1969 427 engine block. The last six numbers do match my VIN numbers. I can't find anything in the black book with this number - what have I got? Thanks
Old Oct 31, 2007 | 02:33 PM
halfmoontrail's Avatar
halfmoontrail
Originally Posted by Muchie69
Hello Everyone,
Sounds like it should be two different sets of numbers, slightly different font size.
First set should be T06 2 LM = 390 hp, mnual trans., assembled june 2, '69.
The other should be 19S723653: the 23,563rd Corvette produced sometime in early July '69.
When you find your trim tag, it should have L## on top right, for July and whatever date.
Yours is near mine, (22,704). After the strike, usually considered late '69.
Steve
Old Oct 31, 2007 | 03:22 PM
Muchie69's Avatar
Muchie69
Default Engine Code
Just went out and rechecked my numbers per your answer and you are exactly right - guess I didn't see the numbers/letters clearly the first time. Also appreciate knowing if early or late as I just thought it was an early model which was a wrong assumption on my part. Thanks loads for the help.
To Engine Code Help
