cruise control not working.
Old Nov 18, 2007 | 07:39 PM
RLS's Avatar
RLS
Default cruise control not working.
My cruise control is not working. I had a elect. short sometime back and it has not worked since. I am wondering if it was unplugged in trying to isloate the short? It has power where it plugs into the fuse block so it has power, but I am wondering if it got unplugged from the switch. Any suggestions as to where to look?
Old Nov 18, 2007 | 07:59 PM
Artsvette73's Avatar
Artsvette73
There is a connectior under the steering column from the main harness . It should be a black connector then look for the wire connector that come out the column the wires are very tin and molded together that connector is very thin. Also see if the cruise is hooked up to the back of the brake switch.
