Anyone Using Torque Thrust Ds
Old Nov 25, 2007 | 12:57 AM
flstfi's Avatar
flstfi
Default Anyone Using Torque Thrust Ds
I have a 77 and want American Racing Torque Thrust Ds in 16". The recommended tire size is 245/50/16. Anybody been there and done that?
Old Nov 25, 2007 | 11:05 AM
zwede's Avatar
zwede
A 245/50-16 is about an inch smaller in overall diameter than stck and will look weird unless the car has been lowered. To maintain stock diameter you'd need a 245/55-16 but I don't know if anyone makes one?
Actually 16" performance tires are going away in favor of 17 and up. Any particular reason you don't want 17" rims? With 255/50-17 tires you get exactly stock diameter.
BTW, be sure to get the right backspace on the rims. If you go with 8" wide rims you want 4" backspace.
Old Nov 25, 2007 | 02:35 PM
flstfi's Avatar
flstfi
Default About tire size
I thought it was the right thing to do after I saw a 17" C3 on McJacks Corvette.com. Not quite sure of the address (google it). C3s look funny with large wheels and less tire to me. As opposed to a C4,5 or 6.
I went to "TireRack.com" where they have a simulator. You simply select your vehicle,wheel and tire and it shows you the car. You can even select the cars color. By the way C3s are notorious for emrgency brake "Cable Rub" with improper tire or wheel size. Please Advise........
Old Nov 25, 2007 | 04:33 PM
vette blue's Avatar
vette blue
I went with the 16" TT II's and Kumo's from tire rack. I just ordered whatever they suggested they fit perfect ride smooth and they dlvd the tires and wheels balanced as one piece. Can't find my paperwork or I'd give you the wheel size. In any case they guaranteed that it would fit and it did. Esthetically i found the 17"was too much wheel and the 16" were cheaper too. However you will have better performance with the 17".
Your choice!
Old Nov 25, 2007 | 04:47 PM
zwede's Avatar
zwede
17" rims with 255/50-17... Looks good to me. But of course I'm biased... it's my car.
Old Nov 25, 2007 | 09:52 PM
vette blue's Avatar
vette blue
The tires tire rack sent me are 235/60/16.
Old Nov 26, 2007 | 02:41 AM
RunningMan373's Avatar
RunningMan373
Torque thrust "D's" only go up to 16"s, the TTII's go up to 20, i think.
Old Nov 26, 2007 | 02:48 AM
rpoL98's Avatar
rpoL98
235's? they're hedging their bets, more concerned with no-fit liability.
sheez, C3's came from the factory with 255 width tires.
Old Nov 26, 2007 | 09:12 AM
zwede's Avatar
zwede
One-piece Thrust D's only go to 16". The 2 piece CL205's that look just like Thrust D's go larger.
Old Nov 26, 2007 | 10:09 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
IMHO, Marcus has nailed the big wheel/tire combo on his C-3 just about perfect. Usually C-3's look like they are on rubber band tires which just looks goofy. Plus most folks leave car up in the air and the fenders look empty like a Hot Wheels car.
The trick was to use relatively *tall* sidewall 17's that fill the fender nicely.
In person..his car just flat *makes it look right*!!
JIM
Old Nov 26, 2007 | 10:20 AM
vette blue's Avatar
vette blue
These are the 16" TT II's. I'm biased as well and think they look good. Mind you the 17" look good as well. I guess it's a matter of personal preference
Old Nov 26, 2007 | 12:05 PM
Aggitated Monkey's Avatar
Aggitated Monkey
You should be biased as the car looks GREAT
17" are perfect on the C-3's
Old Nov 26, 2007 | 02:58 PM
427Hotrod's Avatar
427Hotrod
Those are great looking too Vette Blue. It carries on with the idea of NOT using short sidewall tires. Yours look nice..
But you could drop it down an inch or two and really make it fill those fenderwells up!
JIM
Old Nov 26, 2007 | 11:09 PM
Fastguy's Avatar
Fastguy
St. Jude Donor '03-'05
That looks badass.
Old Nov 26, 2007 | 11:49 PM
retroLS1's Avatar
retroLS1
Great looking cars guys. I am torn between the 16" or 17" look. Either way, the beefier sidewall really helps out a lot. I'm not a fan of the rubber band look, especially with a higher suspension.
Old Nov 27, 2007 | 07:09 PM
danthony's Avatar
danthony
2024 C3 of the Year Finalist - Unmodified
I have the same exact setup.
Old Nov 28, 2007 | 02:33 AM
RIJVETTES's Avatar
RIJVETTES
Man those look great! Now I'm torn between the 16's and 17's. Could you post a couple more shots from the side- and do the 235's fill out the width of the wheel well? Thanks.
To Anyone Using Torque Thrust Ds
Old Nov 28, 2007 | 11:32 AM
vette blue's Avatar
vette blue
Hopefully these pics will give you a better angle on the width.
Old Nov 29, 2007 | 12:03 AM
Curby's Avatar
Curby
Cruise-In VII Veteran
St. Jude Donor '06
I have the 17 x 8 with a 4.5" back spacing and 255/45/17 tires. There is about 1/2" betweent the tire and the e-brake cable, and 1" between the tire and the rear tail pipes when the suspension is fully extended. I like the "tucked in" look, and when I lower it, it will really look great.
The sidewall is not too short, and the wheels are not to big. i may go to an 18 x 10 on the rear with a 275/45/18, just like the C5, if I can get a 5.5" back spacing on it. I will have to relocate the e-brake cable, though.
Old Nov 29, 2007 | 03:01 AM
RIJVETTES's Avatar
RIJVETTES
THANKS. Looks great. Your TT 2's are polished, not chrome? Who makes the tires and how do they grip n wear? Thanks again.
